davidjh72 -
Originally Posted by davidjh72
Cool! Then my 44 PSI rated tires can go to 48.4 PSI!
(sarcasm) but my analog tire gauge only has hash marks for whole units.
My digital gauge isn't much better... it's got resolution to .5 PSI.
Guess I'll set the tires for a hair over 48 PSI to be within the 10% rule.
BTW... ever check your tires to find one tire, or both tires on one side are higher than the others? I drove north yesterday afternoon. It was sunny 70+. My left front was at 50 PSI. The other three were 47 PSI. So the side facing the sun, plus that front tire getting more brake bias than the rears heated up more than the right sides.
"I'm coming in... Gimme a 1/2 turn up of wedge and drop the right front tire a quarter pound! I'm winning this race g'damnit!"
I'm not sure if my typo confused you or you're still being sarcastic. The "10% rule" means that you subtract 10% from the maximum PSI rating on the tire to be safe. If you have 44 PSI, you subtract 4.4 to get 39.6 PSI (as if anyone has a tire gauge that can read that!).
However, you are probably fine at 48 PSI because I lots of people like diamondlarry are running at 50 PSI, no problemo.
I think that the PSI rating is for running the tire at it's maximum speed rating. Soooo, keep it under 120 MPH, mister!
Segway ... From a mechanical engineering standpoint, you want to be "liability safe". When a mechanical engineer sizes an AC unit, he/she calculates the building's worst possible need in terms of cooling BTUs and might add 50% to that number. In that way, the engineer is covered for when something really bad happens. The AC may never run at full capacity, but the engineer won't be sued when all the Movieland Wax Museum statues melt (because they won't).
What does all that crap I just wrote mean? There's a good chance the tire companies rated the PSI for their own legal protection.
PS - There is a really really really good tire website where I read the 10% rule, but I lost the URL
