FE Difference DX vs HF Motor in CRX HF? - Page 2 - Fuelly Forums
Old 10-04-2007, 10:53 AM   #11
mrmad's Avatar
Originally Posted by FritzR View Post
Are you sure the valves will not hit the pistons? The reliefs are there for a reason.
Well if there are 4 valve reliefs in the piston and only 2 valves in the head I think it's a non issue
No, the reliefs are in different places. The 4 valve piston is flat where the 2 valves would hit it. There is no relief there. Plus the 2 valve head may have a higher valve lift then the 4 valve head.
Old 10-04-2007, 12:15 PM   #12
Well I guess I better turn the dx motor into a d15b1 hatchback motor by changing the cam and putting a restrictor plate. The part number is the same for the throttle body for both so I guess the fuel injection from the HF motor would work?
FritzR is offline   Reply With Quote
Old 10-04-2007, 04:27 PM   #13
mrmad's Avatar
Sorry, you completely lost me here.
Please Add Time of Day to Fuel Up Screen xoraclez Fuelly Web Support and Community News 1 03-29-2013 08:03 AM
gasoline and veggie oil, to much time to think. GasSavers_Ryland Experiments, Modifications and DIY 35 06-30-2008 06:20 PM
Interesting article about aerodynamics McPatrick General Fuel Topics 0 06-23-2007 07:11 PM
Buses = FE saving minic6 General Fuel Topics 1 06-13-2007 05:28 PM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 04:27 AM
