exhaust manifold...or headers for FE? - Page 3 - Fuelly Forums
Old 06-27-2008, 09:22 AM   #21
Originally Posted by philip1 View Post
I beleive a tri Y type header is best for FE as it frees up low to midrange torque. I have one of these on my wagon and it seems to have helped a bit...
Tri Y is also known as the 4-2-1. 4 combine to 2, and 2 combine to 1.
Old 06-27-2008, 10:01 AM   #22
If you have a honda D series engine fro 88 on up, the 2 part 4-2-1 96-00 civic EX (d16y8) OEM header is widely available on craig's list for 15-20 bucks and it will fit. I put one on my hatch with a 99-00 civic si cat back and a new 2.5" cat. It took 35$ worth of help from a muffler shop to get it shortened a bit and I installed it myself. The car produced noticeably more torque and quite a bit more power in that last 1500-2000 rpm before redline. I might have picked up 1 mpg or so. I have the welded assembly type oem header, there are also cast iron ones that weigh quite a bit more. Many 99-00 civics have the cat right on the head built into the exhaust manifold. If you replace that type of set up you need to move the o2 sensors back down the exhaust and this requires either buying Honda extending harness(s) or soldering your own extensions.
mini-e is offline   Reply With Quote
Cam regrinds for Atkinson cycle? omgwtfbyobbq General Fuel Topics 14 07-11-2007 07:03 AM
Honda 2005 1.8L i-VTEC 88HF General Fuel Topics 4 07-09-2007 06:40 PM
Air Dam or Belly Pan tor07 Aerodynamics 10 04-07-2007 12:17 PM
