EVAP effects on mileage Currently disconnected. - Fuelly Forums
Old 02-17-2009, 05:53 PM   #1
guest001's Avatar
My evap has been disconnected for quite some time now. Probably since I still had TBI on my civic and shortly after converting to MPFI. I put a 92-95 Intake manifold on shortly after. If your familiar with older hondas you know what I'm talking about. Anyway, I just realized I had the solenoid hookup wrong with my current setup and I plan on install it shortly. but I'm interested if this might increase mileage at all. Well I'll see, but let look at it in a more technical manner.
If you have a 1/2 gallon of water. you put it in a pan and you boil the water for say a couple minutes, then turn off the heat source and let it cool to room temp. you have less water. Same scenario in a car. If I just dump it to the atmosphere I'm wasting fuel. But the question is it really boiling any if at all in the winter at temps between 30-50 F? But there is the exhaust and pump running to heat it up too.
So, if I do hook it up, and since fuel has to be vaporized to burn effectively anyway. and the computer learns that the motors running slightly rich and leaned out the mixture. in theory the evap should increase mileage a bit compared to dumping it..............
guest001 is offline   Reply With Quote
Old 02-17-2009, 07:37 PM   #2
yup any fuel that you burn gives you more power/range. The system is supposed to release the trapped hydrocarbons from the charcoal canister into the engine when you start it up at a slow rate so that is burns cleanly. There have been food hydrocarbons ground up with a blender and cooked with the heat of the exhaust to give off gasses of hydrocarbons and fed into the intake of a diesel in a Humvee and it ran on it. Was on the special about traveling across America on BioFuels - no gas.
Old 02-18-2009, 05:38 AM   #3
Reminds me of Coolfuel Roadtrip, when they used a gasifier to run an RV on waste food.
Old 02-18-2009, 07:16 AM   #4
aalb1's Avatar
I'm not familiar with the term TBI for Honda's but I assume that means Throttle Body Injection? On older Honda's I am familiar with the DPFI system (Dual Point Fuel Injection). I assume this is what you mean.
Let me ask you, what differences did you see in your Fuel Economy? I know there's so many mixed feelings about it. MPFI has the potential to be more efficient if the maps are altered but the DPFI was designed for efficiency from the factory.
Old 02-18-2009, 07:51 AM   #5
YAH That was it!
Old 02-18-2009, 07:59 AM   #6
Eh, you were right, it was a hummer.
What did they run the RV on, then?
Old 02-18-2009, 10:38 AM   #7
Just about everything you might eat - not me but - things like burgers and fries to fruits and vegetables from what I remember. I can't imagine what came out of the cooker after it was used up . . . yuck!
Old 02-18-2009, 10:49 AM   #8
No, I mean...they ran a Hummer on the gasifier, so I must have been confused about the RV. What fuel was the RV running if it wasn't the gasifier?
They did dump all kinds of leftovers in the gasifier, they spent like half the show's length showing what kinds of foods they were making and dumping in. I specifically remember a seafood gumbo. Yuck indeed.
Old 02-18-2009, 10:55 AM   #9
aalb1's Avatar
I'm sure the Fruit Loops in the lower right corner made it smell better!
Old 02-18-2009, 12:53 PM   #10
I think they ran the RV on biodiesel and various oils directly. They also had solar panels on top to power up the electronics I seem to recall. They also ran an electric scooter for some of the trip. Somewhere there was a vehicle with solar panels on top making HHO gas feeding the engine but I think that was the stretch HUMVEE which burnt out the brake rotors coming down a mountain full of twisty turns.
Recent Fuel-ups Graph Scale rcsheets Fuelly Web Support and Community News 5 09-08-2008 04:11 AM
suggestion for stat comparison zahampton Fuelly Web Support and Community News 1 09-04-2008 08:29 AM
any mess with a gsx-r 750? scdave Motorcycles 8 02-01-2008 10:24 PM
Any Golf Cart owners? GasSavers_TomO General Discussion (Off-Topic) 15 07-23-2007 04:06 PM
The 175 Watt Solution: Big companies taking concept of electric bicycles seriously MetroMPG Automotive News, Articles and Products 4 10-11-2006 03:07 AM
