Reverse is easy on an electric motor, even an AC one like you'll most likely be using.
One thing you will need to take into consideration. Is the transmission gear reduction in 2nd going to cause more of a loss than the motor running at a lower RPM.
Do you have any efficiency charts for the motors you are thinking about using?
- Kyle
