Engine warmup and short distance dilemma. - Page 3 - Fuelly Forums
Old 06-02-2009, 06:48 AM   #21
GasSavers_mikemoss's Avatar
A By-Pass filter really earns it's keep in your driving situation.
You need to be using the best synthetic oil also.
Our low-use/low-miles driven Prelude has 100,000 miles on the oil and analysis says it is still fine.
How often do you change the oil with the bypass filter? I have heard elsewhere that with a bypass filter some people just add to it when it gets low. I cant imagine that a bypass filter is that good.
GasSavers_mikemoss is offline   Reply With Quote
Old 06-02-2009, 04:19 PM   #22
KARR's Avatar
Country: Portugal
I've checked the oil, it's not milky, just the usual black. I'm not doing that commute anymore. Now a travel the same distance on a complete straight line, which I will definitely cover it by bike.
You've referred a by-pass filter, I don't know what that is. Can it be installed in a old diesel engine?
KARR is offline   Reply With Quote
Old 06-02-2009, 11:54 PM   #23
The Amsoil by-pass filter cleans down to 1 micron. In about 5 miles all the oil is filtered, so it is analytically clean.
Go here and read details: http://www.amsoil.com/storefront/eao.aspx
I sold the Dakota so fast I didn't have time to remove the by-pass....darn it, so I don't have one on the Tundra.
The Tundra has the Amsoil oil and filter changed at 25,000 miles.
On the Dakota, I changed the full flow at 15,000 miles until the current filter came out. The by-pass filter lasted a year or longer, but I usually only changed it when oil analysis indicated it was necessary. 100,000 miles between complete changes was usual.
