Electronic RPM limiter - Page 2 - Fuelly Forums
Old 02-15-2006, 07:25 AM   #11
Compaq888's Avatar
There is a company that can
There is a company that can flash my ECU but they are complete idiots. I don't want to start no wars so the name won't be mentioned. They can tune the A/F ratio and the RPM to whatever you want. The problem is that when you put it on a boosted car it looses lots of power. When you put it on a nitrous car it blows a motor. You get the picture. What I did for my nitrous setup is I got the MSD box and a narrowband and ran 75 shot at least 15 times. Nothing happened.
Old 02-15-2006, 07:28 AM   #12
Why would it blow the motor
Why would it blow the motor if it was set up for forced induction?
Old 02-15-2006, 07:30 AM   #13
Compaq888's Avatar
Because their program is
Because their program is messed up. I'd rather take my chances with my stock ECU.
Old 02-15-2006, 02:56 PM   #14
Yeah, the kickdown cable, sweet
To clarify, I was just brainstorming on the rev-limiter thing -- like if you set your limit at 3000 rpm for testing and you forget about it, you'll bump back and forth on fuel-cut, which might freak out the ECU and suck gas at that point. I dunno...
BUT, I do now know that the detent/kickdown cable alteration is a brilliant idea, Sir SVO. The only time I need to kickdown right now is near WOT, like if I have to urgently speed up to squeeze onto the highway from an on-ramp, otherwise, I can manually pull it down. I'll find the 3rd cable and loosen it up.
Thanks!
Old 02-15-2006, 04:41 PM   #15
Make sure to post up about
Make sure to post up about your loosening and all that, I am wondering at the results. I baby the throttle so that it's in the highest vacuum possible and it upshifts for me as early as possible (2000-2250 depending on gear). I've never had it shift down when I didn't want to,
suggestion: running averages of data? roadent Fuelly Web Support and Community News 4 10-27-2008 10:58 AM
drivetrain resistance bagpipe goatee General Fuel Topics 9 09-14-2008 10:04 PM
Civic hatchback aerodynamics basjoos Aerodynamics 191 11-08-2007 02:46 PM
BMW C.L.E.V.E.R. Concept MetroMPG General Fuel Topics 4 04-24-2006 11:59 PM
ElectroCharger assist motor to retro-fit any car into a hybrid Matt Timion Hybrid Vehicles 2 10-09-2005 10:06 AM
