Electric water pump - Page 2 - Fuelly Forums
Old 01-29-2007, 11:59 AM   #11
GasSavers_Red's Avatar
Originally Posted by Sludgy View Post
IMHO, any water pump is a terrible idea that wastes gas. Hot water rises. If you mount a radiator ABOVE the engine, it would create a thermosiphon that would move coolant due to density difference.
I never have quite figured out why almost all car manufacturers mount radiators in front of the engine where it creates drag and needs a water pump.
Perhaps the flow rate isn't high enough for sufficient cooling?
Old 01-29-2007, 09:10 PM   #12
bzipitidoo's Avatar
no pump, just convection
John Deere tractors from the 1950s and earlier did not have water pumps. They relied on convection to move the water. The problem was the water passages had to be much larger. The upper radiator hose eventually reached a diameter of somewhere around 4 inches(!) before John Deere threw in the towel and added a water pump.
Another proposal was to run on methanol. Methanol burns at a much lower temperature, so an engine specially designed for methanol would not need a typical water cooling setup. Air cooling is sufficient. Of course, there are old Beetles, with their air cooled engines in the rear. I recall vagulely that it worked, but shortened the engine's life.
bzipitidoo is offline   Reply With Quote
Cost of motoring UK & US Draigflag General Fuel Topics 13 12-12-2013 05:22 AM
More detail josh434 General Fuel Topics 2 06-28-2009 03:39 AM
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
