So, it's time for a build thread on the bike. I bought it for $500 a few weeks back. It came with AGM wet cell batteries. It looked like this:
Now, after adding a paktrakr:
The bike has a new battery frame, batteries, and cover:
Those are LiFeP04 batteries. 3.2v per cell x 12 cells. 90AH. Pretty sweet score from another gassaver! 135#'s less of batteries. The bike has way more low end torque now (not needed as it loses most of it's good torque at 32ish mph).
But, alas, that isn't enough. Current range is limited to about 27 miles (actually not bad given the motor and pack capacity, prior range was 20 miles practical) and top speed is 43mph. It wont actually keep more than 30mph on a good hill; which there are many of in this area.
I'm going to upgrade one tooth bigger on the smaller sprocket (10 tooth to an 11th tooth, started at 9) to help the top speed and gearing a bit, but the aerodynamics are killing the thing. I think harley davidsons have an assumed drag coefficient of .80! man, my car is far superior to that.
So, onto my collection of aluminum:
Any guesses as to where that came from? Think long and hard....
Anyway, I'm making a frame with that aluminum for some coroplast panels to hook too. Here's as far as I got before it became 3 am....
Brackets:
Mock up top bracket:
But wait, no room for my knee!
Much better:
Final view from front:
So, the next step is fabricating the lower bracket which will look very similar, in fact I may just use the top bracket as a template. Then, using those two brackets at templates for the other side, make two brackets that are twins of these. Cut and attach coroplast, voila, lower fairing that is in line with the rear saddle bags. This baby should increase the CdA some, but lower the Cd significantly. It will keep my knees warmer and dryer, especially during the winter months that I plan to drive it!
Other mods planned:
Find or fabricate front handlebar fairing. Install windshield that will be integrated as well. That will keep me warmer and reduce drag to some degree. Anybody have any fairings kicking around they aren't using?
Lower the front fender to wheel level not shock level. Enclose from wheel.
Find a way to make a pseudo boat tail or kam.
Feedback appreciated!
B
