E10 and MPG - Page 2 - Fuelly Forums
Old 08-25-2008, 09:15 AM   #11
Originally Posted by Jay2TheRescue View Post
Ethanol does not have the same amount of BTU's per unit of volume as gasoline. Ethanol will therefore reduce the MPG of a vehicle. Ethanol is used primarily for 2 purposes. It is an effective way of "watering down" the gasoline, and it is used as an oxygenating agent. It helps reduce the unburned HC level in the exhaust.
This is correct, but it's far from telling the whole story behind the power and MPG potentials of Ethanol.
The main loss in MPG people are seeing is because there's less power per cubic foot in ethanol versus gasoline. But there's MANY factors here that people are either ignorant to, or not talking about.
Ethanol can create MORE power than gasoline. Just talk to some serious drag racers. Ethanol is very similar to methanol, but much less corrosive, meaning rubbers and metals that are ethanol friendly are a bit easier to come by.
Why can it make more power? Stoichiometric ratio. The stoichiometric ratio is where a fuel makes the most complete burn. Gasoline's stoichiometric ratio is 14.7:1, and realistically is above 15:1 if you want to use every last molecule of gasoline, and closer to 12:1 if you want to use every last molecule of air. E85 (not even pure ethanol) is around 9.765:1. That's a LOT more fuel at the stoichiometric ratio, meaning more power.
Understand that engines are air pumps, and throttle controls air, not fuel. In an engine designed for gasoline that's now running E10, it's not running as much fuel as it can, thus there's normally a power reduction.
But wait, am I saying that once calibrated for E10 my car will get WORSE gas mileage still? Yup, but there's MORE!!!
Ethanol is EXTREMELY detonation resistant, and detonation (or knock) is the main factor engines are designed around. It's the whole reason engine compressions in the 60's went down so much when leaded gasoline was banned. The lead additive in gasoline prevented knock, allowing companies to run much higher compression getting more power out of every cubic inch of engine volume, and every molecule of gas.
Another huge factor, is that ethanol is extremely versatile on the air/fuel ratios. It can run much leaner and much richer than it's stoichiometric ratio. So, though it needs much more fuel for a given air volume to reach stoichiometric, it can safely run much leaner, and richer depending if you're going for economy, or performance.
Right now, the highest compression production engines are around 11:1. Ethanol only engines can run upwards of 16:1, even as high as 18:1.
If an engine was designed to use E85 there's VERY little data showing weather it would be less or more efficient. Like always, it comes down to too many factors. My personal believe is that it will be a wash either way. Ethanol has more versatility as a fuel, and I think at best it might get a couple % extra efficieny than gasoline, but the offset is that it will be able to create much more power on demand.
As a complete motor head, this is the first "green" tech to ever come along that I've been excited about. For the most part I find tree huggers and the like to be idiots, and rather annoying. They pay little attention to real facts, and make thier own assumption on the way science works.
Ethanol right now takes more energy to make.
I could care less though, because to me at least that's money not going to the middle east right? Even importing sugar can from south america is better than giving the billions we do to the middle east. Though statistically, with sugar cane for every gallon you put into the farming process, you'll gain about 11 gallons back in ethanol. Not a bad conversion.
It might sound like magic, but it's that basic magic of agriculture that we live on every day. You always get more out of the ground than you put in. Obviously it's more complex than that once you add in fertilizers and such, but my point is that even a kid can watch a kidney bean grow to much greater sizes than the origonal bean.
Another thing I like about ethanol is that it's a technology that is still seeing rapid improvement. Oil refining hasn't changed much, and won't change much in the forseeable future. There's lots of possabilities for ethanol.
GasSavers_Gollum is offline   Reply With Quote
Old 08-25-2008, 09:28 AM   #12
True, ethanol from corn is not a good long-term solution for our fuel supply and climate change problems. Cellulosic ethanol will be one of the better options when the technology matures. An even more interesting option is biodiesel production from CO2-absorbing algae:
http://www.oilgae.com/blog/2006/10/g...ioreactor.html
As for Freon, it may be heavier than air, but there is indeed a correlation between CFC production and stratospheric ozone depletion:
http://www.esrl.noaa.gov/csd/assessments/1998/faq1.html
Bill
Nrggeek is offline   Reply With Quote
Old 08-25-2008, 09:29 AM   #13
Originally Posted by Blkzr1 View Post
What is your experiance?
Stock 87 CRX 38+ w/reg---33 w/E10, more than 10% loss.
In testing E10 I find 3.5%-15% ethanol, about impossible to do ANYTHING with fuel adds or tuning on a regular basis.
Well, I'll agree with it would be nicer to have a fixed ethanol ratio, 'coz dialling in the exact mix would be nice... but I seem to be doing better now on E(whatever it is this week)"10" than I did before on "normal" gas plus acetone or other additives, see my threads in the experiments forum.
Old 08-25-2008, 10:32 AM   #14
I notice an increase in not only mileage but performance from running E10.
They should make it a fixed ratio for the E10 but I don't think they are working at it because most cars now are EFI so they don't have to care about air/fuel ratios fluctuating a bit like they did back when E10 was used with carbbed engines.
- Kyle
Old 08-25-2008, 10:44 AM   #15
What I'm hoping, is for someone to make a tank sensor that can calculate mixes. Then that signal could feed the ECU and figure out how to handle the fuel table changes.
Old 08-25-2008, 10:51 AM   #16
AFAIK factory equipped E85 cars do this.
Old 08-25-2008, 10:59 AM   #17
Well then, I guess I need to figure out how they do it and then figure out how to send that data to megasquirt.
I figured they either had a manual switch for E10 to E85, or used agressive knock sensing to tell how much ethanol the mix had.
Old 08-25-2008, 01:37 PM   #18
no one has touched on the adverse affects of E10 on carbed engines...boats, lawn mowers, and the like.
Old 08-25-2008, 01:54 PM   #19
The big adverse effect is either needing larger jets due to the fuel increase, or the corrosion of parts due to the corrosive nature of ethanol.
But with E10 it's really not a big deal. I wouldn't hesitate to run E10 in almost anything, and my lawn mower is currently running it just fine. It's a 4 stroke lawn mower, about 20+ years old.
Old 08-25-2008, 02:22 PM   #20
I think it actually evened out my Buick. Running on the old gas it used to leave a black mark on the body by the tailpipe. I imagine it was running rich, but it does not seem to do that anymore.
How should I start recording? bennieboy Fuelly Web Support and Community News 1 09-17-2011 10:40 PM
best car for city fe? civic94 General Fuel Topics 3 04-29-2008 01:40 PM
Premium Fuel when "Recommended" rh77 General Fuel Topics 9 03-30-2007 04:28 PM
Do you have/ use cruise control kickflipjr Hypermiling 16 03-22-2006 01:53 PM
