e.o.c Question - Fuelly Forums
Old 11-20-2006, 12:48 PM   #1
e.o.c Question
been trying some engine off coasting and noticed that i can keyoff and back on and scanguage stays on but doesn't update average mileage for current trip. instant reading goes to 9999 but current trip stays at whatever it was when engine shutdown. if alot of this is done won't it make the scanguage readings different than what i'll realy see when i refuel.
Old 11-20-2006, 01:23 PM   #2
CO ZX2's Avatar
Lx, do you have your fuel type set to hybrid? Does your speedo work when you key back on? Key has to be ON, not acc.
Old 11-20-2006, 01:44 PM   #3
I have my fuel type set to gas. i'll have to check about speedo or not but i'm sure it does. whats difference with it being hybrid??
Old 11-20-2006, 02:15 PM   #4
As far as I know, they Hybrid setting simply tells the SG to continue functioning/calculating as long as the key is ON, regardless of whether or not the ICE is running. Which is what you want if you're going to do some codfishing.
Hyundai Active Eco System DurhamRich General Fuel Topics 4 05-25-2012 12:46 PM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Intake Manifold Polishing Theory SVOboy General Fuel Topics 32 04-11-2006 08:44 AM
I issue a challenge!!! Matt Timion General Discussion (Off-Topic) 32 01-29-2006 05:28 PM
long time MPG nut JanGeo Introduce Yourself - New member Welcome 8 01-23-2006 02:33 PM
