Dropping the car for aerodynamics - Fuelly Forums
Old 02-18-2006, 04:34 PM   #1
So yep, expect a DIY soon once I finish. I've only done the first half for time reasons, but I'll finish tomorrow, the front it a little unever but when I have them all on I'll fix that,
What do the aero gurus think about drag reduction from this?
Pictures!
Before:
I can't believe one of my stock springs was broken!:
One coilover on:
Half-done shots (driver side is a little too high):
Old 02-19-2006, 06:20 AM   #2
It does help mileage/cd
It does help mileage/cd marginally but usually isn't a cost effective modification if doing for mileage alone. The flow under the vehicle becomes more critical as the vehicle is lowered so a belly pan becomes more desireable. Added benifits are generally improved handly, and depending on opinion looks. On the down side, reduced ground clearance can be an issue, especially living where there is snow. Where I live we have a speed bump that has been known to remove the ground FX off lowered cars.
iburnh2o is offline   Reply With Quote
Old 02-19-2006, 06:41 AM   #3
lowering
Supposed to help if 2.7" I think was the magic number but I would recommend a front skirt that is soft or pops up and backwards when hit or one that you can lower and raise - then the underbody will not matter as much.
Funny but 80 rabbits would break the left front coil at 60,000 miles about a 5 inch length from the top end. I actually remember mine breaking as I was pulling out from an exit ramp onto Main road.
Old 02-19-2006, 06:45 AM   #4
krousdb's Avatar
Do me too!
I saw those springs on ebay. I need this mod BAD! My oversized tires raised everything 1". I would like to drop it back down by 1-1.5".
Old 02-19-2006, 08:10 AM   #5
Haha, I'm glad you saw it on
Haha, I'm glad you saw it on ebay. I got them for free from someone who bought them there,
EDIT: What's this about 2.7 again?
Old 02-19-2006, 08:27 AM   #6
krousdb's Avatar
Re: Haha, I'm glad you saw it on
Another freebie? How do you keep pulling that off?
OK so you will be doing a DIY right? I'm gonna put a set on my ebay watch list. How hard was it to do? Do you need any special tools? How long does it take? I really like the adjustability feature.
Old 02-19-2006, 08:32 AM   #7
I just know a lot of people and I am very patient when I want things.
Anyway, yes diy. It's not very hard at all. Special tools are a spring compressor but I got one on loan from autzone (43 dollar deposit) or you can get them on ebay for 20 or so shipped. Took my like 1:30 for the first cuz my dad was "helping" and slowed me down a lot, but the second only took like 35-45 minutes, back two have a simple construction so they'll be every quicker.
Old 02-19-2006, 08:33 AM   #8
what is it with honda
what is it with honda springs... over 8 years, 3 broke on my accord (all, front, at different times). it's not like i took the car off-roading either.
in aero geek-speak, lowering a vehicle increases its "fineness ratio" - its ratio of length to height. and this is desirable. i hadn't heard of an "optimal" ride height before (2.7).
as for how much it will help, i agree a lot depends on your underbody design & suspension.
lowering my firefly will definitely help because as it sits now, it's very high for its length - i have a ridiculous amount, maybe 5-6 inches, of ground clearance. all 4 control arms angle down quite sharply from the belly plane into the underbody airflow. so shortening the springs will tuck them up higher, and reduce their drag considerably.
on my car, i suspect they went for exaggerated ride height to offer slightly better visibility and improve the "feeling" of safety in such a tiny car. as we know from studies of people who buy SUVs, one of the biggest contributors to their (gnerally false, overall) perception of safety is improved visibility from having higher sight lines.
Old 02-19-2006, 08:42 AM   #9
Honda springs are generally
Honda springs are generally very good, but I have heard that the old accords were flukes suck boxes.
Old 02-19-2006, 09:56 AM   #10
2.7 inches
Somewhere I read - can't seem to find it yet - but the best ground effect clearance for the front skirt is about 2.7 inches - seems that moves enough air around the car instead of under it and reduces air drag. I have about 6 inches and am thinking about adding an adjustable skirt in front that I can raise and lower - should show mpg changes right away.
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 03:01 PM
VW Jetta fast riser coolbreeze General Fuel Topics 5 07-22-2009 12:25 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
Modifying exhaust to increase mileage? Matt Timion General Fuel Topics 15 01-07-2006 08:44 PM
