05-22-2007, 07:14 AM
Driving in neutral bad for engine?
I do a lot of coasting in neutral. This has me a bit worried:
"An idling engine isn't operating at its peak temperature, which means that fuel doesn't undergo complete combustion. This leaves fuel residues that can condense on cylinder walls, where they can contaminate oil and damage parts of the engine. For example, fuel residues are often deposited on spark plugs. As you spend more time idling, the average temperature of the spark plug drops. This makes the plug get dirty more quickly, which can increase fuel consumption by 4 to 5 percent. Excessive idling also lets water condense in the vehicle's exhaust. This can lead to corrosion and reduce the life of the exhaust system."
idling-myths
05-22-2007, 08:34 AM
eoc is said to be bad for a auto tranny but other then that i havent heard much about outer things
05-22-2007, 08:37 AM
you could turn off the engine instead of idling  .
Best tank= 81.23 mpg on july 1st 2008
SAVE SOME GAS, SAVE THE WORLD!
05-22-2007, 09:13 AM
I am no expert on engines, but have heard of the problems you are talking about. Though excess idling I imagine would be ALOT of idling. Not idling for a mile every 2 miles. I also would think that if you idled for a mile and then ran your engine somewhat hard afterwards you would blow out what was deposited during the idle. On the other hand if you were idling for hours I think it would be a different story.
That is my take on it. I am sure some more knowledgeble folks are typing up a reply right now  .
05-22-2007, 09:14 AM
The paragraph you quoted was written to encourage Canadian drivers not to idle to warm up their stone cold cars. Completely different from when you and I idle in neutral with a fully warmed-up engine...
05-22-2007, 09:41 AM
idling-myths
An idling engine should be running at NORMAL operating temperatures within a few minutes. If this weren't so, there are a LOT of police cars that would die prematurely. I just recently got rid of a used police car I picked up on ebay, and I am sure that the motor had a LOT of "donut miles" on it. Main problem that car had was just normal police pursuit and operational wear.
-- Randall
McIntyre's First Law: " Under the right circumstances, anything I tell you may be wrong."
O'Brien's First Corollary to McIntyre's First Law: " I don't know what the right circumstances are, either."
05-22-2007, 04:35 PM
driving in neutral is not bad for anything but if the engine is off coasting down hills then your goinna run into serious tranny problems
05-22-2007, 05:56 PM
|V3|2D
if its automatic
05-22-2007, 08:43 PM
You might wear out your pilet bearing, it's a $6 bearing, but you have to pull the tranny to get to it, and the ones that come with some of the new clutch kits are crap.
otherwise I don't see an advantage of keeping the engine engaged and running fast if you don't need the power, once your engine is warmed up any blow by gasses should get cooked out, along with any water, not letting an engine warm up is when you start to have problems with water in the crank case and in the exaust, the spark plugs use the head as a heat sink, so if your engine is warmed up then the plugs shouldn't foul easly, if you find that they are fouling, then go up a heat range.
05-23-2007, 01:43 PM
Originally Posted by thisisntjared
if its automatic
ye ai forgot to add that....u can do whatever with a manual tranny, just automatics will be toast real quick with engine off coasting
