Double electrodes? Any difference? - Fuelly Forums
Old 09-12-2008, 05:42 AM   #1
Getting ready to tuneup my 93 civic dx hb and am curious: Do more grounding electrodes make a difference? Are 2 better than 1 and are 4 better than 2? I do feel there would be an advantage for having the platinum. With these 100,000mi plugs, has anyone heard if they are still effective at 50 or 75000mi? Thanks! Rick
Civicrick is offline   Reply With Quote
Old 09-12-2008, 06:08 AM   #2
If you go for OEM Platinums then yes, because the manufacturers now sell cars that don't require a tune up for 100,000 miles. A friend of mine just replaced his spark plugs in his 97 T Bird and after ~125,000 miles the stock plugs and ignition wires were still in there. He replaced them and now says the car has a lot more power, but it didn't run "bad" to begin with, and it still passed state emissions with the old plugs and wires. As far as multiple electrodes goes, electricity always follows the shortest path to ground. This means after a period of time it will probably only fire off of one electrode anyway.
Old 09-12-2008, 06:42 AM   #3
Member
Ratman667's Avatar
In my opinion the platnum+(insert number here) plugs aren't worth the price. In a car with a distributor such as yours, they probably wouldn't hurt. However, they probably won't help any either. I know in a car with a DIS ignition system with a waste spark, they have been know to cause misfires (happened to me and a few people i know).
Also, up until recently I worked at a parts store. With the platnum+ plugs being such a high profit item we were given spiffs of 50 cents per plug. So, depending on the sales person, they may try to force them on you.
Ratman667 is offline   Reply With Quote
Old 09-12-2008, 11:32 AM   #4
I kinda guessed as much. I am gonna go with the platinums to avoid the gap increase that affects regular plugs but just with one electrode.
Old 09-12-2008, 01:40 PM   #5
Site Team
As far as I know, a single spark is all it takes to initiate combustion. I don't know what another electrode would accomplish, besides looking cool in advertisements.
-Bob C.
Old 09-12-2008, 01:52 PM   #6
Exactly. Its a gimmick, nothing more. The only way the spark will split 2, 3, or 4 different ways is if the resistance is exactly the same to all electrodes. If the resistance is slightly higher on one or more electrodes those will not spark. Years ago I tried Splitfire plugs (2 electrodes) on my Buick. Absolutely no performance or MPG gain, but @ $5/ea they did make a noticeable dent in my wallet.
Old 09-13-2008, 12:16 AM   #7
-Bob C.
Multiple electrodes provide many paths of least resistance instead of just one.
Think of each electrode being North , South , East and West.
As one wears the spark changes to the next electrode with the path of least resistance.
For example. If the North electrode is wearing and the South electrode is next in line to have the optimum gap the the spark jumps from the centre to the South in place of the North.
As the South electrode wears the spark then goes to the next least worn electrode in line say East and so on.
There IS only one spark but having multiple electrodes allows the gap to stay closer to optimum for a longer period of time hence the longer intervals between replacements.
Cheers , Pete.
GasSavers_Pete is offline   Reply With Quote
Old 09-12-2008, 02:19 PM   #8
The point behind those Bosch platinum multi-electrode plugs isn't the multiple electrodes making multiple sparks.
It's the surface-gap discharge that the design gives you and the fact that it is so open to the combustion chamber.
- Kyle
Old 09-12-2008, 02:24 PM   #9
I recommend using platinum because of the 100,000+ mile change interval. I have ran several sets of platinum plugs in excess of the 100,000 mile recommended change interval with no negative effects in FE or power. The cost of platinum's are only about $2-$3 a plug and last 100,000+ miles. Copper core plugs are $1-$2 each and have a recommended change interval of about 15,000 miles which makes the platinum more economical to use. I could be wrong about the change interval on copper core, I just know that is what was recommended years ago when I used them.
Hipermiler
#47 on my way to #1
Old 09-12-2008, 03:01 PM   #10
Yeah, it seemed I was putting new copper plugs in my vehicles every 12 - 18 months. When I switched to platinum I was able to extend it to several years. Now that I've switched to OEM platinums I haven't worn any of those out yet.
Please Add Time of Day to Fuel Up Screen xoraclez Fuelly Web Support and Community News 1 03-29-2013 07:03 AM
New to GasSavers.org civic_matic_00 Introduce Yourself - New member Welcome 6 05-25-2008 02:30 PM
83 Chevette Diesel - $950 Orange County CA razmataz For Sale 0 02-29-2008 08:59 AM
Larger/Heavier Flywheel rh77 General Fuel Topics 14 09-10-2006 11:54 PM
Name the VX krousdb General Fuel Topics 19 07-02-2006 01:12 AM
