Double electrodes? Any difference? - Page 2 - Fuelly Forums
Old 09-12-2008, 10:11 PM   #1
while two electrodes won't help in the spark department, they do increase the compression a little , which gives more power.
mikehallbackhoe is offline   Reply With Quote
Old 09-13-2008, 07:37 AM   #2
Danronian's Avatar
I've tried bosch-4 plat. plugs in a Honda before that was otherwise tuned-up, and it ran terribly. Switched back to the OEM NGK v-power plugs, and it ran fine.
Any Honda I've bought has always got better MPG with the correct NGK plugs than platinums. I have gone with irridium NGKs once, which did yield the same MPG as the v-powers, and if you are going for a long period of not changing plugs, I would get those instead.
But with a civic, it's so easy to replace the plugs. Just make sure to use anti-sieze on the threads of the plugs and dialectic grease on the wires. I replace my NGK v-power plugs yearly (20k mile interval) and doing that has always gave me a smooth-running car. IN one year they are always rouned where they were pointed and the gap has always increased. But for me $8 on plugs a year and 10 minutes to replace them is always worth it.
Old 09-15-2008, 03:50 AM   #3
Bosch plugs do multiple sparks by virtue of the fact that they are high resistance, thus dribble your spark energy out slowly. This makes them good for some turbo engines 'coz if the spark gets "blown out" there's still charge in the wires for it to re-establish itself. However, they will make weak plug wires etc flash over 'coz the spark tries to find an easier route. Many are the cars that don't seem to like them, Fords and Dodges seem to be in this category. I believe this is because they have relatively high ignition output from the factory, in the 30KV plus range which is reckoned to be HEI when upgrading. Additionally, if you read up about the benefits of plug indexing, and then look at a Bosch +4... you'll notice that whatever you do, it shrouds the spark.
As pointed out, the mileage interval possible on the +4s is partly due to the fact that they have 4x more "edge" for the spark to start from, and also because lower ignition energy density from the higher resistance means that gap erosion is less severe.
Platinum is a good catalyst for many reactions, this makes it good in a motor right? Not really, it will decompose ethanol vapor into water and CO2 while glowing red, it will also catalyze H2 into H2O and glow red... This often happens BEFORE the correct ignition point in a hot motor, thus you get preignition issues. Therefore, platinum plugs may run poorly in combo with E10 or higher, or with a HHO or other hydrogen assist system.
Old 09-15-2008, 11:28 AM   #4
lol theyve had multi electrode plugs for a very very long time (pulled a dual electrode spark plug out of my 1929 model A engine)
everyone ive heard that use the bosh ones have had issues later on or doesnt seem to make a difference...
i just stick to OEM and dont worry about em.
Old 09-18-2008, 10:04 AM   #5
CivicRick,
I was told by a parts person and my toyota mechanic that multi-electrode plugs do not make any difference. I am running a 95 toyota v6. Different make and engine than yours, but, you can increase performance many other ways. If you can see a big difference between using cheap plugs versus the "best" on the market, you may find that something else is really amiss like bad wires or bad Oxy/fuel mixture before combustion. Make sure your main systems, compression, and your plug wires are all good before you make a plug change. When you change the plugs last, any good/bad differences should be attributable to the plugs and nothing else. Also, I have returned plugs before without any problems with my supplier. Ask before you buy, you may be able to test out a few theories before you stick with a solution.
T100Glut is offline   Reply With Quote
Please Add Time of Day to Fuel Up Screen xoraclez Fuelly Web Support and Community News 1 03-29-2013 07:03 AM
New to GasSavers.org civic_matic_00 Introduce Yourself - New member Welcome 6 05-25-2008 02:30 PM
83 Chevette Diesel - $950 Orange County CA razmataz For Sale 0 02-29-2008 08:59 AM
Larger/Heavier Flywheel rh77 General Fuel Topics 14 09-10-2006 11:54 PM
Name the VX krousdb General Fuel Topics 19 07-02-2006 01:12 AM
