Does the Civic VX have a unique alternator? - Page 3 - Fuelly Forums
Old 05-05-2006, 03:30 PM   #21
95metro's Avatar
Re: cool - i didn't know there
Originally Posted by MetroMPG
cool - i didn't know there was such a thing. i'll have to check that out.
(and what was that about not being helpful?)
I guess I have my moments - but don't thank me yet, they ain't as cheap as I thought...
http://www.safetycentral.com/fanbelrepkit.html
...as an alternative just measure the belt size you need and see if you can find a belt from pre-serpentine days that will fit.
95metro is offline   Reply With Quote
Old 05-05-2006, 04:55 PM   #22
how about an old inner tube,
how about an old inner tube, cut to the width of the belt, and stapled together to make a tight band?
i just tried it. my friday after supper project!
i took the OEM belt off, jury rigged the water pump inner tube band, and drove my city "test loop".
some interesting observations:
- the DRLs do not switch on when the alternator isn't pumping out the amps (clever! thanks, suzuki engineers!)
- the engine seemed to run smoother at low rpm, suggesting i removed a noticeable load. it also clutch started smoother (these observations subject to placebo effect & experimenter bias!)
- i got my best mpg ever. 86.0 mpg (US) indicated on the scangauge. that's not "proof" of anything - also subject to experimenter bias. i need to do back-to-back testing using the better methodology on my flat, straight test course.
- surprisingly, the stapled "rubber band" belt stayed together and on the pulleys. i don't think it'll last very long though.
Old 05-08-2006, 07:19 AM   #23
95metro's Avatar
Re: how about an old inner tube,
Well, that's certainly the Jack Benny approach to the problem...
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 10:10 PM
Gas price chart? reppact Fuelly Web Support and Community News 2 11-06-2008 02:35 AM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 05:36 AM
Google Earth Help GasSavers_DaX General Discussion (Off-Topic) 5 06-21-2006 12:44 PM
Civic modified to get 53 mpg. Matt Timion General Fuel Topics 1 09-27-2005 10:57 AM
