Does the Civic VX have a unique alternator? - Page 2 - Fuelly Forums
Old 04-21-2006, 07:05 PM   #11
Send a message via AIM to molecule
so then this optimization
so then this optimization isn't just for the vx...
they all use it...
they wouldn't run the wire for nothing on all the other models...
at least i dont think they would...
and if thats the case...i do nothing but sit idly by and save...
or do you think i need to "do" something to enable the feature
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 04-21-2006, 07:11 PM   #12
The ran all the vtec wires
The ran all the vtec wires and such in all the 92 civics, regardless of vtec, as well as in all the del sols up until the 96 model, I believe. So they might've just put it there.
Old 04-21-2006, 08:11 PM   #13
GasSavers_Randy's Avatar
I think it's in all the
I think it's in all the civics, at least 92-95. However if you look at the list of things needed before it turns on, it wouldn't be on very often. The 10A draw for example means that nothing other than the engine is on.
You could install a switch to ground out the C wire (no need to disconnect it from the ECU), then leave it in low-voltage mode most of the time. I think a few minutes per trip would be enough to top off the battery. Things use about 30% less power at 12.5v.
GasSavers_Randy is offline   Reply With Quote
Old 04-21-2006, 08:15 PM   #14
yeah seems reasonable...as
yeah seems reasonable...as long as memory would serve me to throw the switch...
lol
svo
vtec was pre-wired only in all the 92 civics
after that...only in cars that were equipped w/ vtec engines
BE ZEITGEISTED
Old 04-21-2006, 08:39 PM   #15
Quote:svo vtec was pre-wired
svo
That's what I just said.
Old 04-24-2006, 11:00 PM   #16
GasSavers_Ryland's Avatar
what page of what repair
what page of what repair book gives this information? I've looked at both my factory service cd-rom manual (a pain in the *** to read, i like books), and hanes manual, and haven't found anything.
Old 04-26-2006, 07:42 PM   #17
Re: what page of what repair
In the 1994 Factory Service Manual, first edition it's the back where they take apart the alternator. Page 23-128 and 129. I got the manual from Helminc.com, though I bet your cd-rom is the same thing.
Old 05-05-2006, 02:48 PM   #18
how did i miss this thread.
how did i miss this thread. this site is getting too busy!
i recently heard from a crx hf owner that this was a feature on his car way back in the day (it was an 85 i think). field weakening.
i still want to test my car with the alternator completely disconnected (un belted) and see if it makes a measurable mpg difference.
but i need to keep the water pump going (it's all on the same belt) and not sure what kind of smaller belt to jury rig in there, since it won't be adjustable/tightenable. the panty hose trick? bungee cord?
Old 05-05-2006, 02:58 PM   #19
95metro's Avatar
Re: how did i miss this thread.
Just get one of those adjustable emergency belts from CT. Should work well enough for a few tests.
95metro is offline   Reply With Quote
Old 05-05-2006, 03:14 PM   #20
cool - i didn't know there
cool - i didn't know there was such a thing. i'll have to check that out.
(and what was that about not being helpful?)
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 10:10 PM
Gas price chart? reppact Fuelly Web Support and Community News 2 11-06-2008 02:35 AM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 05:36 AM
Google Earth Help GasSavers_DaX General Discussion (Off-Topic) 5 06-21-2006 12:44 PM
Civic modified to get 53 mpg. Matt Timion General Fuel Topics 1 09-27-2005 10:57 AM
