My steering rack is going on 2 years and 25k miles without PS fluid in it. No failure, noise or any negative side effects. You be the judge.
Even if you drain the rack upside down for a couple of days (I did) there will still be a film of oil left inside the rack coating every surface. Once you seal the banjo bolts to the rack that oil will remain inside for the life of the vehicle. This is more than enough lubrication.
This is a used BMW E36 rack I installed in my E30 2 years ago. I disconnected the PS lines, drained the oil, slipped a couple of very short lengths of hose (red) over the banjo bots and torqued them down.
If you have the time here is the proper way to depower a steering rack.
http://www.flyinmiata.com/tech/depower.php?x=1
Notice that when the pinion comes out, its actually lubricated with grease from the factory, not PS fluid.
The PS fluid doesn't come in contact with the rack and pinion gear teeth.
10% is a lot.
I'd love to get together all the reasonable-looking things that have improved people's fuel economy by 10%. Put them all together and my car would manufacture gas that I could sell.
My bmw has a 1.8 liter 16 valve engine with cams setup for peak power at the expense of low end torque. With PS still in place the idle would actually drop when I turned the wheel at a stand still. My friend managed to stall it once when he was really aggressive with the steering wheel at idle.
cheers
Justin
