Diesel - Page 3 - Fuelly Forums
Old 08-03-2006, 09:39 AM   #21
You could prolly take a heat gun to some coroplast and get it done that way,
Old 08-03-2006, 10:02 AM   #22
lovemysan's Avatar
Originally Posted by Sludgy
I think the truck is just too damned big.
Bingo! How much does it weigh exactly. 4x4 f350 supercrew checked in at a gravel scale at 9700lbs
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 08-03-2006, 11:11 AM   #23
According to Edmunds.com it weighs 6162 pounds. I was surprised, I thought it was a shade under 5000 pounds. Three tons! Good Lord!
Old 08-03-2006, 01:17 PM   #24
lovemysan's Avatar
Sludgy what is your truck exactly. DRW, SRW, x-cab, supercab,etc. I may have my numbers incorrect on the weight of the truck? 6200lbs wet sounds optimistically light to me.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 08-03-2006, 01:23 PM   #25
F350 diesel / automatic / 4x4 regular cab SRW.
Old 08-03-2006, 04:21 PM   #26
lovemysan's Avatar
yep 6200 sounds about right to me. That being the case I would think your mileage could be a bit better. Have you thought about WAI and straight pipe. Also how is your tire pressure.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 08-03-2006, 04:43 PM   #27
omgwtfbyobbq's Avatar
The problem with bed covers is that they don't really clean up much because the drop from the cab to the bed has already seperated the airflow from the top/side. I'd go for underbody/rear wheel covers, a campershell, and maybe airtabs all around. A WAI will only hurt a diesel, but if you really wanted to, a post intercooler water injection system should help out with FE and power. If you can stand it, and had the cruise control at 60mph, try 55mph. You should see ~21-22mpg.
Old 08-12-2006, 08:45 PM   #28
GasSavers_Randy's Avatar
My '79 F250 crosses the scales at about 4600. That's really light these days... like a stripped half ton. With a few common accessories (like a bed-mounted diesel tank), the newer trucks tare over 8000.
GasSavers_Randy is offline   Reply With Quote
Old 12-01-2009, 02:48 AM   #29
garyhgaryh's Avatar
I have a 2002 Chevy 2500 HD Silverado w/ the 6.6 duramax engine w/230k miles and I got 19.6MPG for my last fillup. Not bad for this 3/4 ton truck.
I think I can hit 20mpg if I got a tonneau cover.
garyhgaryh is offline   Reply With Quote
Old 12-01-2009, 07:53 AM   #30
Old thread I know but the nice thing about the old International diesels Ford used is you can pour just about anything in the fuel tanks that will burn.
A buddy of mine in Dallas siphons off oil from a waste oil recycling container and adds a gallon or so of E85 to it and pours that straight into the tank and then tops the tank off with a little diesel. He says it's a little harder to start since he is running 50-75% god knows what oil mix and it is winter but once you get going it runs great and is actually getting better mileage than straight diesel does.
- Kyle
Server Time ynpmoose Fuelly Web Support and Community News 2 12-20-2013 12:53 PM
University Survey PowerHDI Fuelly Web Support and Community News 3 10-31-2013 03:26 AM
Website Funkyness, I see others are having the same problem. I get an error message, seems wiki related. krousdb General Discussion (Off-Topic) 14 04-25-2006 02:47 PM
Is there any interest in a wiki here? Matt Timion General Discussion (Off-Topic) 7 12-23-2005 10:48 AM
