DFCO on honda civic with chipped ecu - Fuelly Forums
Old 10-31-2008, 07:03 PM   #1
guest001's Avatar
is the DFCO controlled independently of the EEPROM (chip) data? or is it programed into the fuel maps. where the computer accomplishes DFCO by having really lean duty cycles/pulse widths for the injectors in the really high area of the fuel maps where the engine would be when your coasting or let off the throttle really quick at a higher rpm where the vacuum would shoot way up?
how would the ecu even know. My guess is that it would go by vacuum. if not that what else?
I ask and am really curious about this now because at slightly above a half of a tank I started leaving the car in gear instead immediately putting it in neutral on hills and where ever I get a little momentum. and I'm on my way to my best tank ever. finally hitting 40mpg.
guest001 is offline   Reply With Quote
Old 11-04-2008, 05:22 AM   #2
using the TPS and VSS as far as I know.
1984 Volvo 242Ti (in storage) Boost+Bosch CIS = :cry:
2004 Pilot EX
2008 Fit Sport
GasSavers_Willard is offline   Reply With Quote
Old 11-04-2008, 06:27 AM   #3
suspendedhatch's Avatar
It's not in the fuel map. It's a separate function.
initial fill up knhobson Fuelly Web Support and Community News 5 02-02-2010 05:13 AM
How to trick the EFI on newer cars... Nightwish Experiments, Modifications and DIY 4 05-30-2008 04:44 AM
my upcoming VW project - need help! bodhi_tree777 General Fuel Topics 4 05-25-2008 02:32 PM
Double your gas mileage(video) Gearshredder Automotive News, Articles and Products 11 11-06-2007 10:11 AM
Heat Pump Hockey4mnhs General Discussion (Off-Topic) 5 10-18-2007 04:46 PM
