Originally Posted by jwxr7
What performance mods have you done to the car?
edit: I just looked at the garage and saw the mods. Are the bigger injectors tuned good? Do you have an adjustable fuel pressure regulator? If fuel psi is too high it could make you too rich.
(I like sc cars too, mine is an 89 xr7 5spd)
Well the staotich or whatever AFR is set to 14.7 (when cruising) and my buddy with the same mods got dyno tuned to 11.8:1 AFR @ WOT. We flashed the tune on my car also. It pulls to 7200rpm with 0 knock. So the car runs good WOT just cruising it runs rich for some reason.
