dosco -
Originally Posted by dosco
UPDATE:
After some dredging of the Toyotanation forums, I found the answer.
Disconnect the DRL resistor in the engine compartment.
Piece of cake, DRLs are now disabled. Should I want to reactivate them (I doubt it) then all I have to do is reconnect the plug.
It would be neat if you or a pal had a ScanGauge. You might be able to see a before/after LOD value change when you are idling. Just a thought.
