Daytime Running Lights (DRL) Question - Page 2 - Fuelly Forums
Old 05-02-2008, 09:28 AM   #11
Originally Posted by baddog671 View Post
Well, if your car is anything like my Metro was, just pull your parking brake up to the first notch. That will be enough to turn all the lights off but not enough to tighten the back brakes since there is some slack in the brake cables. Check it out, yours might be the same way. If you want, you can also loosen the cables just alittle aswell...
I've already disconnected the resistor and the DRLs are now non-functional.
Sorry if I wasn't clear.
Old 05-02-2008, 03:32 PM   #12
cfg83's Avatar
dosco -
Originally Posted by dosco View Post
UPDATE:
After some dredging of the Toyotanation forums, I found the answer.
Disconnect the DRL resistor in the engine compartment.
Piece of cake, DRLs are now disabled. Should I want to reactivate them (I doubt it) then all I have to do is reconnect the plug.
It would be neat if you or a pal had a ScanGauge. You might be able to see a before/after LOD value change when you are idling. Just a thought.
Old 05-03-2008, 05:03 AM   #13
Originally Posted by cfg83 View Post
dosco -
Indeed. Am considering the purchase.
Old 05-05-2008, 04:26 AM   #14
Originally Posted by rvanengen View Post
I might be really confused, but isn't 90W / 4476W = 2% not 20%??
Your math is correct. 4476 watts is 6 hp. 90 watts is about 1/12 hp, or 2% of 6 hp, not 20% of 6.
I've corrected my post #7.
measuring the FE (?) of electric cars Erdrick General Fuel Topics 12 11-26-2007 11:26 AM
coroplast wheel covers ??? holypaulie Aerodynamics 4 08-23-2007 04:28 PM
Save $$$ on Wood Carving you didn't buy. CO ZX2 General Discussion (Off-Topic) 5 06-03-2007 11:56 AM
Need some help mtbiker278 General Fuel Topics 4 04-14-2006 09:16 AM
Any ideas how to install this? Compaq888 General Maintenance and Repair 0 12-21-2005 12:46 PM
