d15z1 into civic coupe lx - Fuelly Forums
Old 08-28-2008, 09:53 AM   #1
i have already swapped everything into the civic coupe, the engine tranny ecu. i am however looking for the egr control box if anyone has one that would be nice. anyways, the only thing im having trouble with is the engine wire harness connections on the passanger strut tower. the engine harness has 4 plugs while the harness going to the ecu only has 3 plugs. if someone could tell me how to solve this problem, or point me in the right direction i would greatly appreciate it
Paulie D is offline   Reply With Quote
Old 08-28-2008, 12:42 PM   #2
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
Well the VX has the extra plug on the chassis harness...since I had a donor VX, I traced all the wires for the "4th plug" to the ECU cut open the wire loom and labeled them, then transfer that part of the harness over to my Del sol...
So see if you can find a wrecked VX and pull the harness out...other wise I'd say either buy the connector with pig tails from Honda(if available haven't checked) or splice in your own connector and run the wires to the ECU, they are for the 5-wire O2 sensor and the EGR...look in the Honda Service manual and you can find all the info you need, check out my build thread I think I posted some links that will help you, feel free to ask any questions I might be able to help I just finished my swap like a month ago...Matt
MPG Noob
03 Mazdaspeed Protege
91 Honda CRX Si
95 Honda Civic VX *RIP 5/20/08
94 Honda Del Slow D15z1 Swapped
Loserkidwac is offline   Reply With Quote
Fix for a wonky Civic speedometer basjoos Experiments, Modifications and DIY 2 05-14-2012 06:31 PM
Wasted Spaces Snax General Discussion (Off-Topic) 6 02-20-2009 03:44 PM
honda ascot milage gains... Philip1 Motorcycles 9 06-16-2008 03:08 PM
Platinum Gas Saver Jim Jackson General Fuel Topics 22 01-14-2008 01:17 PM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
