D15Z1 CRX Hf - Page 5 - Fuelly Forums
Old 11-04-2007, 01:30 AM   #41
Matt Timion's Avatar
Originally Posted by McPatrick View Post
I know it's an old thread but I was wondering how this project ended up? Did you get it all working well? What kind of gas mileage are you getting now?
It would be great if, now that you (and I am supposing here you did complete the project) completed it could share your thoughts about it, give out some tips. What were the major problems you had to tackle? What would you do differently now (if anything).
If you have the time it would be superb if you could make a DIY with loads of pictures!
CLick on "little blue" in Bunger's garage. You'll see his results.
Old 11-04-2007, 04:16 AM   #42
Thanks Matt, that does show a very good gas mileage. Would like to hear more about Dunger's experiences though. Is this FE pretty much due to putting the VX engine in or are there other mods as well (I am reading some stuff about making the car lighter)?
McPatrick is offline   Reply With Quote
Old 11-04-2007, 08:20 AM   #43
he has drastic weight reduction. If I remember correctly, the 1988 CRX HF was 1819lbs in it's stock condition. Bunger has it down to 1500lbs. I'm sure it makes quite the difference on such a small car.
Old 11-04-2007, 08:23 AM   #44
If you have a solid cel (not blinking) that means that something is seriously FUBAR'd.
Old 11-13-2007, 01:54 PM   #45
MakDiesel's Avatar
I certainly hope not, she starts right up, runs like silk, smooth idle, a bit of hesitation when I give it plenty of pedal but it hasn't been run more than say, 4 miles since the swap was completed last April (drained the tank, new fuel filter, etc) I ground the wire that Rywire instructed me to off the pigtail and I get a steady check light on the stock '89 HF cluster. O2 isn't new but looks decent, P07 ECU is from someone on this board. ? Mak
'85 CRX Si Original EW3 @ 254k...suck it Detroit
'89 CRX HF-Z1 ~ When haste is needed
'97 Civic DX Hatch ~ Formerly 600hp, now 0hp, soon 115hp.
MakDiesel is offline   Reply With Quote
Old 11-13-2007, 02:14 PM   #46
DarbyWalters's Avatar
You can always cut a potato in half and then rub it on the windshield...acts like Rain-X in a pinch. Then stick a hald on the end of your broken antenae for better reception.
Old 02-20-2009, 10:33 PM   #47
Bunger's Avatar
Looks like I'm mothballing this car for a bit. I've been driving some of my other CRX's lately, and getting back behind the d15z1 isn't much fun. I don't want to totally get away from MPG, so I've decided to go with a little moderation. Next project is my 88 Si, I've pulled the B18C swap and picked up a 96 HX swap (d16y5). Also, I have a ZC tranny sitting in storage which should be a nice balance between MPG and performance. I'm hoping for around 45mpg and a 1/4 mile 1 sec quicker than the stock 88 Si specs.
Anger is a gift!
- Zack de la Rocha
Old 02-21-2009, 03:19 PM   #48
good to here from you again, it's been a while.
Filter by Imperial vs. U.S. Gallons? bvz2000 Fuelly Web Support and Community News 4 05-02-2013 08:33 PM
gasoline and veggie oil, to much time to think. GasSavers_Ryland Experiments, Modifications and DIY 35 06-30-2008 06:20 PM
Google Earth Help GasSavers_DaX General Discussion (Off-Topic) 5 06-21-2006 12:44 PM
Am I ever going to be a hypermiler???? Compaq888 Hypermiling 33 05-15-2006 06:44 PM
Friction Reducer kjvman General Fuel Topics 1 01-22-2006 07:52 PM
