CX vs VX vs HX - Fuelly Forums
Closed Thread
Old 07-02-2006, 11:07 AM   #1
CX vs VX vs HX
So, it's pretty simple to see that the VX totally wanks on the CX, and that the CX totally wants on my DX, so I know the CX I have will be an upgrade, and the VX I want will be from there, also.
However, you can't do a cylinder head swap on the DX with a VX head without a very high compression motor (very small combustion chamber mated to dished pistons in the VX block) so I've been thinking about an HX head.
The HX makes 23 more HP than the VX, but I figure that's mostly in VTEC, and it also has a 1.6 and not a 1.5 like the VX. But anyway, the HX doesn't have super small parts like the VX, but it has VTEC-E, and I know it's a step up from the DX, but will it be a step up from the CX if I choose to buy one? Iono, and I certainly don't want to do A-B-A with head swaps, not that it's even possible, but yeah...
SVOboy is offline
Old 07-02-2006, 11:22 AM   #2
krousdb's Avatar
Not sure about the gains of the VX over CX. If any it would be on the highway. As far as the HX, the FE is way lower than CX or VX. I know the car was heavier but personally, I wouldn't go for the HX.
But what do I know anyway.... I suck mightily.
krousdb is offline
Old 07-02-2006, 11:25 AM   #3
The fuel economy on it does suck, but I think if I never hit vtec then it wouldn't suck quite to much, but I really have no idea.
I think the vx is prolly 20% over the cx, hell, lean burn alone is 10%, and it's got some other interesting properties, besides just being built better.
SVOboy is offline
Old 07-02-2006, 11:38 AM   #4
krousdb's Avatar
I think you are too optimistic on the VX, at least in my case. Remember, my engine is either under load, climbing a hill, or it is off. I doubt that I could climb a hill in lean burn mode so lean burn is not feasible during my commute. There may be some small gains due to reduced internal friction, 200 lbs less weight, better aero drag and a taller tranny. I'm hoping for 5-10%.
Now for highway cruising, that is a different story. Lean burn would work great for that. I just need to find the highest speed that will allow for sustained lean burn and hold it just below that speed. Hopefully 50mph or above.
krousdb is offline
Old 07-02-2006, 11:40 AM   #5
Well *shrugshrug* then, it's all the same and I don't care.
SVOboy is offline
Closed Thread
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 04:13 AM
More flexibility in Fueling up Dustin Fuelly Web Support and Community News 0 08-13-2008 02:53 AM
E85 and 10% Ethanol in Unleaded some thoughts ketel0ne General Fuel Topics 2 07-27-2006 03:10 PM
Diesel Kleen cetane booster diamondlarry General Fuel Topics 10 11-10-2005 02:27 AM
