cx to vx swap is it worth it? - Fuelly Forums
Old 04-27-2008, 06:50 PM   #1
silversol's Avatar
i have a 94 cx civic and i found a complete running vx swap for 300$ what diffrence could i see mpg wise?
silversol is offline   Reply With Quote
Old 04-27-2008, 07:23 PM   #2
You won't . You mind as well sell it.
To me .....
Lucky find !!
I would think you could see a significant increase in FE.
From what I have been told from mechanics, the most tricky part is rewiring the cars wiring system for the new engine.
Nerds laugh at me is offline   Reply With Quote
Old 04-27-2008, 07:32 PM   #3
silversol's Avatar
well could i see as much as 10mpg?? what more would i have to wire besides vtec and the egr?
Old 04-28-2008, 03:42 AM   #4
civic lover's Avatar
Yes I believe you could see a 10 mpg increase if properly tuned. I think you have to rewire the O2 sensor. I think... I thought the cx had a 4 wire O2 sensor and the vx had the 5 wire.
civic lover is offline   Reply With Quote
Old 04-28-2008, 11:18 AM   #5
Danronian's Avatar
To install the VX motor you will need to rewire the o2 sensor to a five-wire, run a wire to the ECU for vtec, and wire-up the EGR control box.
Other than that, it is straight forward. If you can't install the swap yourself, it would probably take a very long time to recoup the cost of paying someone to install it and in that case, just stick with the CX motor.
The transmissions/clutches/exhausts are the same between the motors, so you could sell those parts off of the VX swap in order to fund the swap.
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 11:54 PM
Show Your Sign! Rick Rae General Discussion (Off-Topic) 16 09-25-2007 07:56 PM
Hey people: enter your location in your profile please MetroMPG Fuelly Web Support and Community News 7 02-18-2007 08:58 AM
