Custom/Performance tires and wheels for economy? - Fuelly Forums
Old 01-11-2007, 05:40 PM   #1
My 95' civic hatch need tires bad. I looked at some 90k and even some 100k mile tires because they should have harder rubber = less resistance. But, they are not available in my size, so I wanted to go up to 15 inch wheels anyway. If I go ultralight and narrow on the wheel and go as narrow as possible on the tire, can I increase my economy? What is the ruling formula (tire+wheel combo) in order to get the best economy? Thanks.
ob1coby is offline   Reply With Quote
Old 01-11-2007, 06:14 PM   #2
There should be some good LRR (low rolling resistance) tires in your tire size. As I'm sure you've noticed, most economy cars have small wheels. An ultra light/narrow wheel does reduce rotational mass, but if you go up in size, generally you'll have to run lower profile tires to keep from raising your car and screweing up the speedometer. These are generally high performance tires that sacrafice rolling resistance for ultimate grip.
The other big problem with aftermarket wheels is their open wheel design. Ideally we want nearly closed wheel designs. As flat as possible to reduce aerodynamic drag. Some cars on the forum are using these devices commonly called "moonies" that do a great job of this.
Old 01-12-2007, 06:51 AM   #3
anyone with pictures of moonies?
Old 01-12-2007, 07:33 AM   #4
lindermant's Avatar
moon eyes brand hub caps:
http://www.mooneyesusa.com/catalog/p...ac32edcbe10bb3
lindermant is offline   Reply With Quote
Old 01-12-2007, 04:12 PM   #5
they just snap onto your wheels??
Old 01-12-2007, 08:36 PM   #6
lindermant's Avatar
mine snap on, but moon eyes make diff models (snap on, screw on, dzeus fastener, etc).
Old 01-12-2007, 09:38 PM   #7
The Toecutter's Avatar
Do they make different colors, or do they all come in silver? If I get a set, I may have to paint my own custom design on them.
Old 01-12-2007, 10:22 PM   #8
GasSavers_Ryland's Avatar
I wouldn't put any tires on that are wider then 165mm wide (first number in a tire size is the width) I would prefer 155 or 145 (not sure if you can still get 145 in the US).
I've thought about getting moon hub caps, we got some for my moms geo, and they make the car look extreamly slick, but on alot of wheels the outer edge of the rim sticks out more then anything else, so I would think you could go with perfectly flat sheat/disk hub caps, insted of the slightly convex moon hub caps.
Found a bug BDC Fuelly Web Support and Community News 0 12-08-2013 04:31 AM
Windows vs. A/C DHA General Fuel Topics 7 11-19-2009 07:57 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-22-2008 12:25 AM
Diesel Kleen cetane booster diamondlarry General Fuel Topics 10 11-10-2005 02:27 AM
