crx hf vs. civic vx - Page 2 - Fuelly Forums
Old 05-09-2007, 10:11 AM   #11
in my opinion i would say the HF would be better, i am not biased of course
besides the HF looks alot better than the disgusting 92+ civics (excluding the newest model 06?)
white90crxhf is offline   Reply With Quote
Old 05-17-2007, 05:17 PM   #12
pyramid_head's Avatar
Send a message via Yahoo to pyramid_head
I know this is an old thread, but they're both great cars. Vx if you need the space; HF if you like cruising solo or if you're single.
www.onetruth.com
pyramid_head is offline   Reply With Quote
Old 05-17-2007, 08:40 PM   #13
kickflipjr's Avatar
I like them both, but I have always loved CRXs (unfortunately they are a dying breed around here). My pick is for the HF.
2008 EPA adjusted:
Old 05-20-2007, 09:34 PM   #14
GasSavers_bobski's Avatar
While I've never driven a 5th generation Civic hatchback, I suspect the VX would be more functional for day to day life. As people said above, the VX has a back seat. It's hatch area is also longer and has a hatch that's more functional for loading and unloading cargo... You should be able to just plain fit more stuff in the VX.
The HF's reduced weight and front anti-sway bar should make it feel more nimble and sporty than the VX. The technology used in the HF engine is a good bit simpler than the VX engine, so you're looking at less stuff to fail, and cheaper repairs if it does. By the way, it uses 2 compression rings and a set of oil control rings, same as the other models.
If you're mechanically inclined, you could swap a VX motor into an HF. The HF's aero with the VX's lean burn engine should give you better mileage than either car could achieve in stock form.
The HF and VX motors are in the same engine family, so the HF's transmission, clutch/flywheel, engine mounts and A/C compressor would all bolt up like stock. The only odd thing would be trimming the timing belt cover to fit the HF's driver's side engine mount. Not exactly rocket science.
The wiring could be a handful, but conversion harnesses can be purchased online if that kind of thing bothers you.
Let the games begin! Matt Timion General Fuel Topics 4 12-12-2021 12:04 AM
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 08:48 AM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 04:27 AM
Need advice/info-Metro/HF related GasSavers_Lance General Fuel Topics 19 09-06-2006 10:12 PM
Google Earth Help GasSavers_DaX General Discussion (Off-Topic) 5 06-21-2006 12:44 PM
