CRX HF Transmission Rebuild - Fuelly Forums
Old 01-02-2006, 04:53 AM   #1
Moderator
GasSavers_DaX's Avatar
Well, I got the 10-Ton bearing puller/pusher set for Christmas that I've been lusting over, so now I can start the rebuild on my HF transmission and complete the 5-speed conversion on my 4-Door DX. I'll document the project in this thread. Here's a teaser picture:
Old 01-31-2007, 08:42 PM   #2
how much did the bearing separator and puller cost you? did you really need the separator for the mainshaft bearing? mine usually will just come of by pulling(maybe i shouldn't do that?)
this is what i use to pull the bearings on the differential...(yes that is a cheap piece of crap harbor freight bearing splitter, and yes it's bent)
it does take a little elbow grease to keep the differential from turning the way i do it. i'll have to take a picture of how i put the differential bearings on without a press
white90crxhf is offline   Reply With Quote
Old 02-01-2007, 04:16 AM   #3
Moderator
I bought my bearing tools from McMaster-Carr and spent about $200. They have been a good investment though, as I have rebuilt a few transmissions with them.
From my experience, I have been able to pull the mainshaft end bearing by hand on all Honda/Acura transmissions, but the diff and countershaft bearings on D-series transmissions require the puller. Only the diff bearings in B-series trannies have required the puller so far as I have experienced.
I'm interested in seeing how you reinstalled the diff bearings. Bearings in oven and diff in freezer? I've done that before doing countershaft bearings.
Old 04-05-2007, 06:51 PM   #4
UfoTofU's Avatar
I would really like to rebuild the HF tranny that I just got, just for peace of mind.
Dax, would you mind taking a look at the pics of the tranny I got and giving me your $0.02 worth?
http://www.gassavers.org/showthread.php?t=3022
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 09-15-2010, 03:37 AM   #5
Moderator
Re: CRX HF Transmission Rebuild
I still peek in once in a blue moon....
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 12:14 AM
gasoline and veggie oil, to much time to think. GasSavers_Ryland Experiments, Modifications and DIY 35 06-30-2008 05:20 PM
Am I ever going to be a hypermiler???? Compaq888 Hypermiling 33 05-15-2006 05:44 PM
Friction Reducer kjvman General Fuel Topics 1 01-22-2006 06:52 PM
thought this article was interesting bagpipe goatee General Fuel Topics 1 09-06-2005 09:57 AM
