cruise control cut-off - Fuelly Forums
Old 07-02-2007, 09:58 AM   #1
Send a message via AIM to Raccoonjoe Send a message via MSN to Raccoonjoe Send a message via Yahoo to Raccoonjoe
OK, someone mentioned a switch to disable the servo in your cruise control module. I've spent the past 2 hours here searching for any way to do that, but can't find it.......I'm extremely curious as to how this works. In the perfect world, it would allow for the cruise control to lock the throttle, but would still dis-engage when the brake pedal is depressed. Anyone have ideas??
Raccoonjoe is offline   Reply With Quote
Old 07-02-2007, 10:17 AM   #2
GasSavers_Red's Avatar
It should be the only wire running to the cruise control vacuum plunger
Old 07-02-2007, 10:52 AM   #3
If it was only that easy....you of all people should know how difficult Jeeps can be
I can't find the diagram online, so it's attached PDF time....
*edit*
The computer gods don't like me today...the attachment isn't happening right now.
From the ECU, I've got 2 wires....then 1 wire running to the brake switch, and a ground. It's those 2 wires from the ECU that I think I need to get into....but I was curious to know which wire did what before cutting.....
Old 07-02-2007, 11:03 AM   #4
CO ZX2's Avatar
Long Lost Link.
This link may be what you are searching for.
http://www.gassavers.org/showthread.php?t=3748
A neat idea and I think he got it to work as planned. CO ZX2
Old 07-02-2007, 11:20 AM   #5
That's the one, thanks!! Now to tear into my CC, and see if it will apply to me.....
Old 07-02-2007, 11:22 AM   #6
*edit*
Whats your setup look like? Pics of mine below. You should have a 4 pin plug hooked up to it with the following pin out
1 tan/red - vacuum solenoid control
2 light green/red - vent solenoid control
3 dark blue/red - brake lamp switch output
4 black - ground
I think you want to tap into both lines 1 and 2 to prevent it from moving the throttle advance
ID:	561   Click image for larger version
Old 07-02-2007, 11:53 AM   #7
That's exactly the way mine is set up, according to the wiring diagrams in my Haynes manual. I'll have to crawl under there and poke around tonight, see what exactly is under all that grease and slime. Perhaps I'll end up with 2 switches, who knows??
New graphic idea MatrixDom Fuelly Web Support and Community News 2 03-11-2012 01:17 PM
More chart options gt1 Fuelly Web Support and Community News 1 04-12-2011 05:58 AM
Average fuel mileage line in the history graph? BDC Fuelly Web Support and Community News 1 05-06-2009 01:07 AM
Modification page zpiloto Fuelly Web Support and Community News 0 01-12-2007 05:45 AM
speculate: Will a fixed IACV help gas mileage? SVOboy General Fuel Topics 8 04-09-2006 12:49 PM
