crackpot idea or should I be cleared for takeoff? - Fuelly Forums
Old 04-13-2011, 10:37 PM   #1
Here's a link to a fellow Lubbock, TX crazy-dude with a novel idea for an FE mod: the upside down air foil.
http://lubbockonline.com/stories/101...18379023.shtml
I'd bet if you had a really nice, efficient airfoil section, you may not have to pay too high of an aerodynamic tarrif to get the requisite amount of lift.
doctorgonzo is offline   Reply With Quote
Old 04-13-2011, 11:18 PM   #2
theclencher's Avatar
Re: crackpot idea or should I be cleared for takeoff?
Yeah, good luck with that!
I was about to contact the writers but then I noticed how old the story is. :/
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 04-14-2011, 04:35 AM   #3
Site Team
So by creating upforce, he's trying to reduce rolling resistance?
Old 04-14-2011, 05:07 AM   #4
tradosaurus's Avatar
I want to see real data (MPG) on his idea.
tradosaurus is offline   Reply With Quote
Old 04-14-2011, 05:07 AM   #5
GasSavers_Erik's Avatar
The lift would only take a bit of weight off his rear tires/wheel bearings at high speeds and would come at a big aerodynamic penalty.
If you take this idea to the extreme, does a small 4 cylinder airplane get as good of mileage as a car of the same weight traveling at the same speed, say 70 mph? I would doubt it- from what I recall about looking up the mpg of small planes a few years ago, their mpg is in the mid 20's at best.
Old 04-14-2011, 06:00 AM   #6
That is what I think, too.
Also, it would have to be retractable and only deployed during certain conditions. Wintry roads, heavy rain, sharp highway curves (like I-95 through Providence/Pawtucket RI; also every entrance/exit ramp I take) all contraindicate lift. It should also be retracted at lower speeds where it won't generate appreciable lift but will make plenty of drag.
Finally, even in optimal conditions it could mean the difference between a successful crash-avoidance maneuver and a loss of control. I really don't think it's safe to remove as much traction as you'd have to lose in order to gain an appreciable effect on rolling resistance.
The article says this:
?The lowest percentage improvement I?ve had in gas mileage is 25 percent,? he said. Coming after tests that put the savings at closer to 50 percent, he added, ?I felt like that was a failure.?
Rolling resistance is NOT 50% of energy expended.
Old 04-14-2011, 06:29 AM   #7
A well designed wing could improve aerodynamics.
Years ago, I saw an article about a New Beetle with this huge, funky spoiler that lowered its drag coefficient.
The owner was an aerodynamic engineer with access to CAD, and maybe a wind tunnel.
Old 04-14-2011, 12:35 PM   #8
Dammit, that Beetle "wing" is a spoiler and it's not producing lift.
Evidently that Texas "pilot" never had flight training, or forgot all of it. Even the very beginners are taught that lift = drag, and more lift = more drag.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Help Needed! thewolfwagon Fuelly Web Support and Community News 2 05-17-2012 05:44 PM
My VX idle bounces when rolling in neutral djenyc General Maintenance and Repair 20 10-29-2008 08:08 PM
Fuelly for international? pixelthing Fuelly Web Support and Community News 8 08-11-2008 08:32 AM
New Term: EOI 101mpg Automotive News, Articles and Products 1 06-20-2008 11:32 AM
OBDII Questions krousdb General Maintenance and Repair 1 05-07-2006 05:18 AM
