could someone explain DFCO and coasting to me? - Page 2 - Fuelly Forums
Old 04-20-2009, 05:26 AM   #1
sounds dumb, but i have yet to find much detailed info on DFCO mainly and when to use as opposed to neutral coasting.
it was my understanding that the ECU will go into DFCO under higher rpm coasting...i.e. engine braking. any truth to this? what exactly triggers DFCO? when should i try to educe DFCO and when should i just neutral coast? i'm mostly a neutral coaster for now, but the more mpg's the better
btw i'm driving a '04 hyundai accent 5 spd. manual.
zero_gravity is offline   Reply With Quote
considering rear turbulence management Philip1 Aerodynamics 35 10-10-2008 07:45 AM
That, was gross. dkjones96 General Maintenance and Repair 5 09-15-2008 03:34 PM
FE diference with belt fan or electric GasSavers_pcp Diesels 1 05-28-2008 11:04 AM
94 Accord manual trans swap- which trans has the tallest gears? GasSavers_Erik General Maintenance and Repair 2 05-25-2008 07:01 AM
CRX on CVCC body? 101mpg Experiments, Modifications and DIY 6 04-27-2008 06:38 AM
