Contradictory tips. - Page 2 - Fuelly Forums
Old 09-09-2008, 04:23 PM   #11
@mathowie After a few fillups and calibrations, you'll find your new ScanGauge gives a more accurate results. But even if it's initially off by a few percentage points, the relative feedback is still useful for fuel usage feedback.
sbilik is offline   Reply With Quote
Old 09-19-2008, 03:04 PM   #12
Here's My take on this whole issue. I have owned and driven many cars and trucks, both with Manual Transmissions and Automatics. If you are in control, ie manual shifting, you can get exceptional mileage. I averaged 23-25 combined mpg in a 2000 Corvette with the manual. I accomplished this by accelerating in 1st, 2nd briskly, but not fast just enough to stay away the 1-4 skip shift, then letting the engine rpm drop until I could get into 6th and lope at 40-45. I also used this technique in my 2003 C2500hd Duramax, a got 19-21mpg around Phoenix. The Blazer that I have listed currently has an 700-r4 automatic, I accelerate smoothly up to at least 45, so it can shift into 4 and lockup the torque-converter, if I don't get above 42 or so it will hang in third gear at 1750 rpm, but in 4th around 1270 rpm or so.
That's My .02
Later
ophawk is offline   Reply With Quote
Old 09-19-2008, 03:15 PM   #13
I forgot to finish my thought. Engines are more efficient operating under a load, Higher numerical gears. Keeping an engine rpm high and lightly loaded wastes fuel, a medium loaded engine in it's operating range will be more efficient. Their is no hard a fast rule that you can only shift into 5th after you get to 50mph, if your engine has enough torque, up-shift, it will save you fuel. One of the reasons I dislike Automatics, another is they take some HP to turn their oil pumps, and are generally heaver than their manual counterparts.
Later
