Concerning methods of measurement - Fuelly Forums
Old 09-17-2005, 12:41 AM   #1
I have some ideas about how we should measure fuel economy. I believe that the most accurate way to measure mpg is with highway driving. There are simply too many variables in city driving to get consistent results without taking an average over many gallons of gas. Driving style can fluctuate on a daily basis, as well as temperature and humidity that could effect performance. Highway driving involves practically no starts/stops and speed is always kept constant eliminating a lot of human error. Because of this I think one could get by with using less gas in each test. It would take me almost a month to go through 3 full tanks of gas as required in the experiments posted. I don't know about you but I like my results immediately. Going on a joy ride for an hour or two is a nice way to measure mpg so long as you keep it on the highway. I suggest that maybe we should have the new standard for measurement be confined to something like 100 miles of continuous highway driving at 65 mph.
Now I'm not saying that every test should only involve 2 to 3 gallons of gas, but I think that will give a good idea about if the concept being tested really works or not. If gains are shown, the concept can be verified by extended tests. No need to waste gas on tests that aren't going to help.
As for measuring fuel consumed during the test, I believe the top-off method is accurate if done properly. You must fill up before and after the test at the exact same pump at the same gas station. If you used pump #3 at your local Shell, go right back to that pump at the end of the test for measurement. Different gas stations (and different pumps even) can have varying cut-off points to prevent overflow. I once tried to test fuel economy in my wife's Civic by topping off before leaving, then again at my destination about 60 miles later. The calculated gas mileage was about 70 mpg because the second pump switched off much earlier than the first one. Also, don't add any more gas once the pump automatically stops itself. Make sure the pump is pushed all the way into the fill hole. That might affect the cut-off point, too.
Just a few ideas on how to accurately measure mpg. Please share your thoughts and opinions on this. I am eager to participate in the experiments posted but it will take me a long time to go through 3 tanks of gas, not to mention inconsistent driving style, weather, and frequent changes from city to highway driving would introduce error in my results.
Flatland2D is offline   Reply With Quote
Printable History? yelloscoot Fuelly Web Support and Community News 2 01-21-2012 12:15 AM
