Originally Posted by Fourthbean
I did notice the market for flow sensors in boats was quite large, I just did the calculations and I think 1.5GPH lower limit accuracy(what most boat sensors go down to) would just work for me. At 1.5GPH that would give me accuracy up to 28MPG. And since I pulse and glide that accuracy would be better as my engine would be running only have the time making that an effective accuracy of 56MPG.
Found a sensor on Ebay, I will see if I can find a navman GPS for a good price and maybe I will spring for the two together.
Lowrance makes a line of boat GPS that are built to take flow meter input and directly indicate MPG on the GPS.
I've seen my boat read in the few tenths of a gallon while idling. I'm sure you loose a tiny bit of accuracy at very low flows due to the way turbine meters work, still quite good enough. My boats Navman has always been within 3% of the gas pump.
