Competition Averages - Page 2 - Fuelly Forums
View Poll Results: Keep the current average, or implement a cumulative calcuation
Keep the Current Calcs: MPG for each tank is averaged in the total 0 0%
New: Cumulative Miles per Cumulative Gallons = Final Result 12 100.00%
Voters: 12. You may not vote on this poll
Old 07-27-2007, 08:25 AM   #11
brucepick's Avatar
Originally Posted by CO ZX2 View Post
rh77, Rick,
Guess I'm not understanding this very well. How does the proposed new rule differ from the currently posted Version 2.0 rule quoted below??
Excerpt from current Version 2.0 rules:
Calculations:
6. The ?Final Percentage over EPA? is figured by the cumulative, Gaslog-sourced MPG values vs. the vehicle?s EPA FE-Combined (?Cycle-End Cumulative Percentage Over EPA?) ...
If I may be so bold as to answer this one...
Actually I don't think the proposed method does vary from #6 above (my interpretation of it anyway). I think the method of averaging all the mpg values from the gaslog doesn't really reflect #6 as it weights the miles in a short tank much more heavily than those in a long tank.
I think it's a matter of us agreeing on what was the intention of the rule, and stating it clearly so there won't be a question on it.
My two cents.
My thanks to Rick and to all of us for following this.
Old 07-27-2007, 09:21 AM   #12
Single Fills not Effected
Originally Posted by LxMike View Post
I don't think a rules change in mid "season" is right. with the mileage that some get here they would only get 1 fill and it would get posted near end of cycle.
For the season, single-fills wouldn't be affected. It's when multiple tanks are used:
Example:
Tank 1: 400 mi / 15 gal = 26.67 MPG
Tank 2: 350 mi / 13 gal = 26.92 MPG
Tank 3: 100 mi / 3 gal = 33.33 MPG
The current method takes the MPG averages: (26.67 + 26.92 + 33.33) / 3 = 28.97 final MPG
Proposed "cumulative" method: 850 miles / 31 gal = 27.41 MPG
The newer method weights each "gallon" equally as Bruce just mentioned.
Baselines would be calculated similarly...
-Rick
Old 07-27-2007, 09:49 AM   #13
brucepick's Avatar
Note, in Rick's example above, the 100 mile short tank had by far the best mpg of the three tanks So when averaging the three individual tank mpg numbers the short tank pulled the result up to a higher number.
For a case where the short tank has a very low individual score, averaging the individual tank mpg's together will give you lower score than you would get if you average by dividing all miles / all gallons.
Old 07-28-2007, 06:23 AM   #14
CO ZX2's Avatar
I just selected cumulative calculations when I voted. A vote should not have been necessary. This method is delineated in the Version 2.0 rules and should have been used from the start. But anyway, good to have it straightened out.
Old 07-28-2007, 06:42 AM   #15
Cumulative makes more sense. If I fill every great tank at 3 gallons, then let the bad ones run until I am nearly empty, it will be falsely bumping my standing.
Old 07-28-2007, 11:47 AM   #16
Cumulative. That is the only way it makes sense and seems fair to me. I alwags thought it was that way but did not pay much attention.
usedgeo
Old 08-06-2007, 09:45 AM   #17
s2man's Avatar
Ditto
Ditto. I thought we were doing cumulative, and I didn't bother to look a the calculations in the Standings spreadsheet.
Roll on,
S2man
s2man is offline   Reply With Quote
Average MPG calculation?? GizIQ Fuelly Web Support and Community News 2 04-06-2010 04:28 PM
EOC problems repete86 Transmissions and Running Gear 9 11-13-2006 08:52 AM
The state of commuting in America theclencher General Fuel Topics 32 10-21-2006 06:21 PM
Brake and light inspection SupraRXZ General Maintenance and Repair 8 10-04-2006 01:06 AM
Old article...water injection...Condensator.... ZugyNA General Fuel Topics 2 07-23-2006 10:03 AM
