Civic VX upshift indicator location? - Fuelly Forums
Old 02-15-2011, 05:25 PM   #1
Hello,
Sorry if posted in the wrong place, a few questions for the VX owners:
1. Does anyone know where the upshift light is located? Is it below the temp gauge? Going to order the temp gauge from a close friend at Honda, I already have the tach. The car was salvaged and I am restoring it, currently has a DX cluster in it.
2. What years has the upshift light, 92-52 Cali and Federal, or only federal 94-95?
2. My cali VX was converted to 48 state, will the shift light work if I already converted to 5 wire O2 and ECU?
3. In this pic, is the upshift light pictured?
cpforyou.com/pictures/honda/cluster-9295-civic-vx.jpg
onefasteg is offline   Reply With Quote
Old 02-15-2011, 08:25 PM   #2
vxdude's Avatar
Send a message via Yahoo to vxdude
Re: Civic VX upshift indicator location?
Yes, the pic does show the shift light, right below the temp guage. inside the square. I am pretty sure the shift light came in 92-95 Federal VXs only. Not Cali. If you have the O2 sensor and ECU and everything is hooked up right it should work...good luck
vxdude is offline   Reply With Quote
Old 02-16-2011, 12:32 AM   #3
Thanks for the help.
Old 02-20-2011, 11:32 PM   #4
I have a 92 CA vx converted over to the FED and I can tell you that the upshift light doesn't work. I have the 5 wires O2 sensor and the FED ecu but the upshift light still doesn't work. I don't know if i'm doing something wrong or if there's something else that I have to do for it to work but I couldn't get it to work. If you looking for a VX cluster with the upshift light mine is forsale.
GasSavers_viperguy is offline   Reply With Quote
Old 03-03-2011, 08:54 PM   #5
Cool, I will pass on getting one, money spent elsewhere is better.
Regarding it not working, I think I seen it on another forum that you have to wire it in under the dash.
This May Help shatto General Discussion (Off-Topic) 0 07-25-2010 02:41 PM
ICE loads basjoos Experiments, Modifications and DIY 9 11-11-2007 09:32 PM
DSG and CVT Erdrick General Fuel Topics 2 10-13-2007 06:41 AM
