Civic Vx higher idle? - Fuelly Forums
Old 04-22-2008, 10:02 PM   #1
Just wanted to know if anyone has experienced this. My vx was idling around 200-300 rpms at idle. Now its idling at 800 rpms. I recently changed the oil and used some mobil 5w30 full synthetic. Now im thinking maybe it had 10w30 before? which caused it to have a lower idle? So my question is will changing the oil back make the rpms at idle go back down?
civicordie is offline   Reply With Quote
Old 04-24-2008, 09:30 PM   #2
GasSavers_Ryland's Avatar
I started to use 10W 40 oil instead of 0W 30 because my ideal was bouncing up and down and it fixed the problem, it is also common for the pcv hose to leak right where it goes in to the oil separator on the back side of the engine, it's a $2 grommet to replace and about and hour or more of work if you have big hands.
Old 04-25-2008, 05:23 PM   #3
Member
What kind of tach do you have in your car?
92VX is offline   Reply With Quote
ICE loads basjoos Experiments, Modifications and DIY 9 11-11-2007 09:32 PM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 09:48 AM
DSG and CVT Erdrick General Fuel Topics 2 10-13-2007 06:41 AM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 08:47 PM
