City vs. Highway Routes - Fuelly Forums
Old 05-12-2006, 11:22 AM   #1
95metro's Avatar
I just read kickflipjr's signature and he's completely right. A little over a week ago I measured my most common city/highway routes using Google Earth.
I was rather surprised to find that my city routes to the same destinations were anywhere from 2 to 4 km shorter than the highway paths (even though they take the same or slightly longer travel time).
Plus I use less fuel in the city since the Metro's little 3-cylinder isn't pumping as hard to keep up to the 110 km/h highway traffic. Coasting and key-off techniques are just money in the bank then.
95metro is offline   Reply With Quote
Old 05-12-2006, 12:41 PM   #2
This will be one of the
This will be one of the things I test soon, however, there is now only one route to work, I guess I have a friend I visit once in a blue moon though,
Old 05-12-2006, 01:11 PM   #3
zpiloto's Avatar
Yes I've change my commute
Yes I've change my commute because of the scan gauge and its instant feedback. I found I have 3 options depending on time of day. I was driving what I though was the best route because of light traffic and higher speeds but it was using more fuel. Between google earth and the scan gauge you can really look at a lot of options if there is more than one way to go to work. The fastest and flatest does not alway use the least fuel( at least for casper).
Old 05-12-2006, 06:31 PM   #4
kickflipjr's Avatar
I really need a scangauge to
I really need a scangauge to see what driving route uses less gas. Total gallons used is more important (but is not as sexy as a high mpg number :P).
2008 EPA adjusted:
Old 05-14-2006, 09:35 PM   #5
Compaq888's Avatar
for me freeway is
for me freeway is better.
I'd rather have more miles than low miles and poor fuel economy.
Old 05-15-2006, 12:19 AM   #6
philmcneal's Avatar
nah man if city is played
nah man if city is played right, you can beat your highway epa rating with ease. Its just your time will be required as well as your technique.
on the highway engine load is as high as 50% that's how much of a ***** areodynamic drag is.
Old 05-15-2006, 12:44 AM   #7
Compaq888's Avatar
Re: nah man if city is played
hate to break the bad news but on a freeway I can acheive double my street mpg if I wanted. I overcomed drag by installing a belly pan and kept changing the design till it worked just right. I changed the belly's design 3 times now. I also have the undertrays in the front of the car. So far I'm getting around 40mpg on the freeway at 65mph. Next time I will get taller tires and will bump that number up 1-2mpg.
Car was with mechanic - let idle for a while - how to handle? 5mall5nail5 Fuelly Web Support and Community News 15 02-16-2012 06:47 AM
Can't see my car in it's category whiterice Fuelly Web Support and Community News 2 11-10-2011 11:18 PM
fuel-up entry suggestion fugalaya Fuelly Web Support and Community News 3 04-12-2009 08:29 AM
Greetings from Japan. GasSavers_Diemaster General Discussion (Off-Topic) 8 07-13-2006 06:56 PM
