Check engine light code 48 - Fuelly Forums
Old 05-20-2008, 07:42 AM   #1
92VXHatchguy's Avatar
I took my car to a mechanic to check why the CEL was coming on and code 48 came up, LAF (linear air flow sensor)problem. Has anyone experienced this? I'm getting on average, 28mpg. I'm getting horrible gas mileage for this car. What should be fixed or changed out?
Former VX Owner
DD is a 1993 Civic Si Hatchback
92VXHatchguy is offline   Reply With Quote
Old 05-20-2008, 08:47 AM   #2
EH3
EH3's Avatar
48 is lean air fuel sensor
http://www.jdmuniverse.com/forums/sh...ad.php?t=57615
replace the 5wire primary o2 sensor.
EH3 is offline   Reply With Quote
Old 05-20-2008, 09:42 AM   #3
I'm not sure if it's the same, but the mechanic showed me on his computer which said Linear Air Flow Sensor. Either way does this point to changing out the o2 sensor?
Former VX Owner
Old 05-20-2008, 10:49 AM   #4
EH3
EH3's Avatar
the scanner has the wrong description.
VX and HX are the only ones with a lean-burn/wideband o2 sensors. i'm 99% sure that's your problem especially given the horrible mileage
search on honda-tech.com
Old 05-20-2008, 12:30 PM   #5
jadziasman's Avatar
It is a linear air flow sensor - it is commonly mistaken as lean. It's called linear because the voltage/lambda relationship is nearly linear - unlike a narrow band sensor which most definitely isn't.
If the CEL stays on all the time and reads code 48, then it's likely the sensor.
If not, the sensor may be fine and you have another problem - misfiring cylinder being the most likely source although there are other possibilities.
Old 05-20-2008, 01:31 PM   #6
suspendedhatch's Avatar
Either way it's referring to the O2 sensor.
Old 05-20-2008, 02:49 PM   #7
I'm hoping that if I change out the o2 sensor, it will improve my gas mileage as someone said it would earlier. Did any one here have the same problem, and if so, did changing out the o2 sensor fix it?
Former VX Owner
Question on a fuel injector switch 91CavGT General Fuel Topics 18 09-04-2007 11:38 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
