Good observations, guys; thanks for sharing. May a new and inexperienced hypermiler offer some additional thoughts?
Originally Posted by fuelmiser
1. Find the First Available Parking Spot.
... but not necessarily the
first available parking spot.
What you said is bang-on for people who circle or idle for five minutes just so they can park next to the mall entrance. But don't overlook opportunities! Scan the lot as you approach and keep your eyes open; you may find a "pull through" you don't have to back into or out of. Or you may be able to park on a beneficial incline, and that potential energy will help you get rolling again.
3. No More Fast Food Drive Thrus.
Somewhere I read an
enormous figure for the amount of gas and pollution that would be saved if drive-throughs were outlawed.
All these things are a little anal but this is the only message board that would understand where im coming from!
Anal-retentives likely make the best hypermilers.
Originally Posted by Jim Dunlop
Also, when you glide to a stop sign, don't slam on the brakes too early before reaching it. Pop the car out of gear at 65 MPH (for a country highway)...
You'll get better gas mileage at a lower speed.
... glide that thing right up until the stop sign, then slam on the brakes. The idea is to waste as little time idling as possible -- that's why it's better to glide at a fast speed than a slow speed.
... but not universally.
Like several other aspects of hypermiling, this one has a "sweet spot." If you barrel up to a stop sign at 65 and slam on the brakes (not what you were suggesting) you do minimize idle time, but you also throw away a huge amount of kinetic energy that you paid for one way or another. If you go to the other extreme and take your foot off the gas a few miles early so you crawl up to the stop sign at idle (again, not what you suggested), you don't scrub off any speed wastefully, but you spend a lot of time effectively at idle. (Example: If your idle consumption is 0.3GPH and you're rolling at 1MPH, you're getting about 3MPG! On the other hand, if you're rolling at 10MPH, that's 33MPG, which is approaching respectable.)
Somewhere between those two extremes is the most efficient point. My gut feeling is that it's closer to the long-coast end. It'd be nice to see someone run some numbers or gather some empirical data on this.
When it's a traffic light instead of a stop sign, things get trickier. I've been coasting in to reds hoping they'd turn, but a lot of times I wind up having to stop at the light... just in time for it to turn green again. Grrr.
It's a bit of a gamble, but as I begin to learn the timing on some of the lights on my commute, I've tried slowing early (engine braking a little before starting my neutral coast). Sometimes spending a little more time coasting at a slower speed means the light goes green before I get there, and I don't have to dump all that kinetic energy by stopping. The net result is that a slower coast actually results in higher net fuel efficiency.
It's a fun game, ain't it?
Rick
