Car computer for data logging - Fuelly Forums
Old 10-11-2007, 01:35 PM   #23
cfg83's Avatar
Fourthbean -
Originally Posted by Fourthbean View Post
Alright, tested the ups theory and read around a bit more. My ups will not allow me to turn it on without ac power applied, so I would have to get another that would allow such a thing and then I would have to be hitting an extra button each time I turn the computer on. What's funny too is that the 250VA UPS couldn't handle the computer, it would shut down when going to battery power. If I took the video card out and unplugged the hard drive it would work ok. lol
I think I will just go buy an inverter. If I don't use it in the end it will be a nice tool to have around for road trips or something.
cfg83, explain to me what you mean by being able to turn on and off gizmo's. Can I actually control the ECU/PCM through the OBDII port?
This would be a far down the line thing, but let's assume you have the program running and your PC comes with 2 serial ports. The first serial port is taking that data from the OBDII port. Over time you discover that under data input condition A, B, and C, it would be cool to turn on Gizmo X that you have designed and/or bought. Now you can use the second serial port to turn on the gizmo. To turn on the gizmo, you could just turn a pin on the serial port to "on". A relay could be attached to the pin, which is used to turn on the gizmo. Alternatively, you could have a complex serial port protocol that does fancier things in relation to a fancier Gizmo Y. Also, you don't need a second serial port. A parallel port, USB port, or some kind of peripheral connector could do the trick with the right software (that you write or modify for your own porpoise ).
Attachment 980
I am doing all of this but realizing that I am diving headfirst into stuff I know almost nothing about :0.
Don't worry, the main win will be getting the OBDII connection working so that you can soak up all that data (like gravy to bread!!). I just ordered the same elmscan as you, so I will be doing similar stuff. I won't be as ambitious though. My goal is to have temporary data logging setups with a laptop where I can log ALL the data that the elmscan is able to see. Then I can have fancy graphs saying "here is what happens" instead of what the ScanGauge is willing to tell me in real time.
PS - Thanks Red for pointing out the elmscan!
Hovercraft 88HF General Fuel Topics 2 06-21-2007 10:41 PM
DIY: Wire Tuck!!! SVOboy Experiments, Modifications and DIY 11 09-21-2006 04:17 AM
