Can I EOC with a 97 prizm? - Fuelly Forums
Old 02-15-2009, 03:25 PM   #1
i'm just trying to squeeze a bit better gas mileage with my car, its a 3 speed auto (yea i know it sucks), the tranny code is A130. same as the 97 corolla
just want to know if its safe for the tranny, like just put it in Neutral, and shut the engine off. I heard somewhere that some transmissions need fluid circulating when its moving, or something like that. thanks!
civic94 is offline   Reply With Quote
Old 02-16-2009, 05:56 AM   #2
GasSavers_BEEF's Avatar
I didn't think you could EOC an automatic. I would definitely wait until someone told me otherwise. transmissions are expensive. I want to say you can do something to kill the injectors but you leave it in drive when you do that. I still think people are talking about stick shift cars when they say that too.
stay safe, and don't burn anything up.
Old 02-16-2009, 06:55 AM   #3
There are few automatics that you can EOC.
One way to find out is to look in the car's manual or check RV forums/newsgroups to see if it can be flat-towed. Another way is to try to find out if the transmission oil pump is driven by the input shaft or the output shaft. If it's driven by the output shaft then you can EOC. Finally, there are some that are abnormal designs and can EOC; AFAIK older Saturns have an automatic transmission whose design is more like a manual transmission.
Old 02-16-2009, 09:37 AM   #4
yea but how would you bump start the engine when your speed is too low? that is the part I don't understand. I have heard of people coasting (engine off) into their driveway and just parking it, but to do it on the road and having to start the car again while rolling?
Old 02-16-2009, 10:01 AM   #5
Ah...that's a whole other question. You wouldn't bump start; it's possible (neutral drop) but I suspect it would put a lot of wear on the transmission. You'd electric start. It's slightly less efficient than bump starting and significantly more annoying (IMO) but still worthwhile.
Old 02-16-2009, 01:11 PM   #6
I EOC'd a few days before I asked this question. hope i didnt burn anything, the longest ones that i did was about 3/4 mile.
im just used to EOCing with my civic 5 speed and my new 3 speed auto prizm is getting bad gas mileage no matter how i drive.
Old 02-16-2009, 01:47 PM   #7
transmission swap?
maybe not worth the hassle
Old 02-17-2009, 12:17 PM   #8
is it ok if I put it in neutral and coast, with engine on? or its the same as EOC?
i checked the owners manual, its not flat towable
Old 02-17-2009, 12:29 PM   #9
Neutral coast is okay, the hydraulic pump in the transmission continues to operate while the transmission is in neutral.
- Kyle
Old 02-17-2009, 12:59 PM   #10
^What he said. Also, try to rev-match when going from N to D.
So, I got a Scion with a problem... Help? Ratman667 General Maintenance and Repair 17 08-14-2012 09:51 AM
Airtabs - Where's the best place to get a deal on them? Jay2TheRescue Aerodynamics 27 07-31-2008 04:00 PM
WTB Civic VX near WA slogfilet Wanted to Buy 5 04-29-2008 12:24 AM
Anybody using veg oil in/near Vermont? oneinchsidehop Diesels 2 01-30-2008 08:25 AM
Any jeep cherokee owners out here? GasSavers_rav Aerodynamics 5 01-17-2008 04:18 PM
