Can a saturn LW hypermill? - Page 2 - Fuelly Forums
Old 01-03-2008, 01:43 PM   #11
I intentionally purchased the car sans crossbars because of the aerodynamic drawbacks of having them
Old 01-03-2008, 03:33 PM   #12
cfg83's Avatar
philip1 -
Most excellent. Are you also looking to remove the sidebars down the line?
Old 01-03-2008, 03:36 PM   #13
the roof rack is a problem because the side curtain airbags are located right below the mounting points. Not being an explosives expert I'm not going to risk my life taking the rack off.
Old 01-03-2008, 05:42 PM   #14
cfg83's Avatar
philip1 -
Ok. I would have the same trepidation. If you disconnect the battery, you could disable the mechanism, but I would be worried about putting it back together correctly, i.e. exploding after battery connecting.
I was toying with the following idea if I had a Pontiac Vibe with sidebars like yours :
BEFORE :
Attachment 1143
AFTER :
Attachment 1144
It could be a removable kamm-back. It would start at the beginning of the sidebars because it would be designed to mask the sidebars from the air-stream. Sooooo, there would be a large horizontal sheet/roof component also starting at the beginning of the sidebars. The purpose of the "sunroof wind deflector" would be to insure that wind/air doesn't get under the horizontal sheet of the kamm-back at speed and turn it into a sail :
Attachment 1145
The sunroof wind deflector could be replaced with something cheaper like duct tape (at least initially).
ID:	978   Click image for larger version
Old 01-04-2008, 09:33 AM   #15
You may want to pick up a Haynes manual for the car; it should give the proper protocol for working around the airbags, and is useful for lots of other things as well.
GasSavers_Bruce is offline   Reply With Quote
Old 01-04-2008, 01:37 PM   #16
I have one and I am still not going to mess with them. The manual has proven quite usefull in other areas.
Tire Pressure Inflation - what is too much? 1993CivicVX Automotive News, Articles and Products 11 09-23-2007 06:54 PM
FS: VW Cabrio EV in CO - cheap! $2800 MetroMPG Electric and Solar powered 5 08-21-2007 11:43 AM
Claybar results pics + pics of mods lovemysan General Fuel Topics 3 06-25-2007 03:00 PM
Biobutanol: Discussion in the UK rh77 Automotive News, Articles and Products 8 01-24-2007 07:08 PM
Belated Intro GasSavers_brick Introduce Yourself - New member Welcome 4 12-22-2006 07:48 AM
