Cams for FE - Fuelly Forums
Old 12-27-2010, 07:16 PM   #1
GasSavers_Shrek's Avatar
Cams for FE
hello again
i have a book called "how too make more horsepower" by david vizard and in it said that less lift helps fuel atomization (thus better fe), is this true?
and while i was looking at animations of how the prius' atkinson cycle works and i was wondering instead of leaving the valve open still in the compression stage, why not close it before it gets to bottom dead center, so there is less resistance in compression thus theoretically more fe
thanks
GasSavers_Shrek is offline   Reply With Quote
Old 12-27-2010, 09:04 PM   #2
DRW
Re: Cams for FE
Closing the intake cam late is good for maximizing high rpm power as well as low rpm Atkinson type efficiency. Closing a cam before bdc will kill power everywhere.
Dave W.
Old 12-28-2010, 12:17 PM   #3
imzjustplayin's Avatar
Re: Cams for FE
and the reason for that is because then the engine is effectively working against itself to suck in air just so that it can burn less fuel.
Old 12-28-2010, 03:53 PM   #4
Member
Re: Cams for FE
Thats also the reason cars with variable cam advance retard the intake cams at cruise (reduced pumping losses).
GeneK is offline   Reply With Quote
MPG not Shown cafepuya Fuelly Web Support and Community News 8 02-14-2011 04:57 AM
40 MPG on winter blend! GasSavers_DaX General Fuel Topics 5 01-03-2006 05:31 AM
