Broken Odometer - Fuelly Forums
Old 11-19-2009, 03:36 PM   #1
Broken Odometer
What should I do if my odometer doesn't work? Should I just look up how far everything is before I actually leave to go there?
PReta is offline   Reply With Quote
Old 11-20-2009, 01:28 AM   #2
You can use a GPS... but really, you should get your odo fixed.
Stouts is offline   Reply With Quote
Old 11-20-2009, 02:35 AM   #3
Member
Also a ScanGauge has MPH but you have to cal it with a GPS. But I agree with Stouts, get your odo fixed.
VWJunky is offline   Reply With Quote
Old 11-25-2009, 02:12 AM   #4
Forgive me if i'm wrong, but is a working odometer not vital for a valid MOT certificate?
Old 12-02-2009, 12:52 AM   #5
You can probably find a gauge cluster with a working odo in it pretty cheap in the junk yard.
Reineke is offline   Reply With Quote
Old 12-07-2009, 12:17 AM   #6
If you can afford a GPS, you can probably afford to get a working used/junked odo/cluster installed.
Bravo12 is offline   Reply With Quote
Old 12-15-2009, 04:18 AM   #7
Member
get the gear kit from http://www.odometergears.com/bmw.html. you'll have to check to see if you have a vdo or motometer instruments, and it might help if you pull your instruments and the tach to verify that you're ordering the correct gears.
i've been through this on both BMWs that I've bought - the gears WILL break. even if you somehow find instruments with working original gears, they won't last long, and it'll throw off your car's odometer reading. buying new gears is the only reasonable way to go, even if it's a bit pricey.
rem83 is offline   Reply With Quote
