Boiling Gas? - Fuelly Forums
Old 10-17-2012, 06:44 PM   #1
GR8MPGcrx's Avatar
Boiling Gas?
Hi all.
Just throwing the idea around for turning gasoline in to a vapor? Was planning on using a TBI equipped auto as my guinea pig? I have a drawn up prototype, but just was probing around to see if anyone has tried something like this?
Thanks,
alex
GR8MPGcrx is offline   Reply With Quote
Old 10-17-2012, 07:14 PM   #2
Arrow
#1. Boiling gasoline is not safe.
#2. There are many components of gasoline that don't vaporize. You will be left with quantities of this sludge, and no safe way to dispose of it.
Old 10-17-2012, 07:17 PM   #3
It's certainly been discussed. Here's a currently active thread that was about it.
http://www.gassavers.org/f6/1986-pon...car-14178.html
Old 10-18-2012, 12:29 AM   #4
GR8MPGcrx's Avatar
Thank you. I did not know about the fiero. Interesting how some technology just never seem to make it big. In this particular instance, high mpg concepts and working Ideas.
125 mpg carb sure would be nice right about now.
I did look at the post, how does the fiero turn fuel in to vapor?.
Old 10-18-2012, 08:35 AM   #5
This looks like a decent explanation:
Henry "Smokey" Yunick -- Fuel vaporizing carburetor system
Old 10-18-2012, 03:55 PM   #6
GR8MPGcrx's Avatar
Ok. so I read up on Smokey, quite the fellow. From what I understand , he was having his modified fuel line run by multiple hot contact areas along its way to the engine, and also adding a non cooled turbo that was modified so it to would be at a high temperature. All building up to the desired 400 deg F target intake temperature.
Did I soak that up correctly??
Old 01-14-2013, 01:04 PM   #7
They have added ethanol and many ofter chemicals to help "clean" your engine. So you got 15% ethanol. lets say another 5% other.. So a total of 20% non fuel that really screws with these carbs. If you get 100% petroleum gasoline you can make these work again. Funny how they fixed us from building these.
Jooky is offline   Reply With Quote
Old 01-14-2013, 04:25 PM   #8
Ha! My xB has a plastic intake manifold so you can imagine gasoline attacking that if it was hot! Yeah boiling alcohol ... Not a good idea since it sort of boils all at once, better to use throttle body injection and heat the body plus add a vortex generator in there too!
Old 01-21-2013, 06:59 AM   #9
You'd be inclined to read up on....
Vapor lock - Wikipedia, the free encyclopedia
before proceeding.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Vtec-e automatic engine question... metalslug General Fuel Topics 3 05-17-2012 12:57 AM
Toyota Trouble Shooting bowtieguy General Maintenance and Repair 3 05-07-2012 02:05 PM
Vortex Generators shatto Aerodynamics 3 05-05-2012 04:28 PM
Read this VX_Arky General Fuel Topics 2 04-29-2012 02:02 PM
