Block Heaters - Fuelly Forums
Old 11-25-2007, 03:09 PM   #1
Thumbs up Block Heaters
I finally installed my block heater into my swift.
This thing is the best mod I have done to date.... My first
tank almost matched my best summer tank.My best summer tank
was 715km to 31L. My last tank with outside air temps was
around 2 degrees to 6 degrees Cel.The final numbers for that
tank with sometimes a huge head winds was 685km to 31L.
I used the heater on every trip for about 1 to 2hrs before
start up.Still testing my other mods will post more results
later.
green swift is offline   Reply With Quote
Old 11-25-2007, 05:10 PM   #2
brucepick's Avatar
What kink of heater?
Installed into freeze plug?
Or maybe the kind that heats the oil in oil pan?
Old 11-25-2007, 05:46 PM   #3
Snax's Avatar
I just ordered a 1000W coolant tank style heater today. On a small 4-cylinder, it should warm everything up within 1-2 hours. I did allot of reading and research on the various methods and decided on this type because it can work the fastest without the risk of overheating since it is regulated.
I think it makes more sense to use a higher power unit to heat quickly because you end up wasting allot of energy by running a lower power unit all night. A $20 timer set to kick on 1 hour before I leave for work should work well with this.
I think the oil pan heaters probably work ok, but not well enough to have a 'warm' motor when it's really cold out. You also have to watch out for the non-regulated ones which can push 400F! I don't think motor oil is really rated for that. So you end up with a heater that creates a hot spot that isn't enough to really warm the motor fully.
I opted away from the freeze plug style for the higher wattage and easier installation.
LiberalImage.com
I think, therefore I doubt.
Old 11-25-2007, 07:08 PM   #4
I'm using a 400 watt unit. When colder, it is set on a timer to go off around 3.75 hours before I unplug and drive off. SG shows WT around 29°C (85°F). Any longer and it doesn't go any higher, the heat just gets sucked elsewhere.
Just under 2 hours gets the same deal early fall...
Old 11-30-2007, 06:18 PM   #5
Heaters
I use the clamp on heater with some mods. It works as long as I have it on for at least 2.0hrs. I am also going to try amsoil 0w30 next change to try to fend off the cold weather blues....
Green Swift
Old 12-01-2007, 12:37 PM   #6
Anyone found a cap?
Mine is 30°C/86°F WT. If I leave it plugged in, that's as high as it goes. Tough part is gaging when to trigger the timer to come on to get to 30° without wasting a few hours if it gets there too early?
Old 12-03-2007, 06:11 AM   #7
VX trainee
I did some shopping, found the best deal on Amazon.com.....1000watt tank heater $40.62, 1500watt tank heater $46.33. They also have 375-650 watt water hose heaters, I used to use that style, worked OK for me.
I'm going to install a 1500 on my VX, and two 1000s on my kids' cars. They're parked outside, so this'll be a nice Xmas present! Now all I need is a couple of 50' extension cords.....
4bfox is offline   Reply With Quote
Old 12-03-2007, 08:09 AM   #8
GasSavers_TomO's Avatar
Just an FYI for the Honda guys...The stealership can usually get you the OEM screw in freeze plug heater for around $40. Takes up less space than the tank style heaters, takes no more than 10 minutes to install.
Honda Civic VX Info/Links
Old 12-03-2007, 08:31 AM   #9
GasSavers_Erik's Avatar
Tractor Supply company- $32 for a 1000 watt tank type unit, thermo regulated 135-175 degrees
http://www.tractorsupply.com/webapp/wcs/stores/servlet/ProductDisplay_10551_10001_33681_______14345|14397 |14410|14413|33681?listingPage=true
Note: the pic shown on the website ad is not correct- this is a tank type heater that you plumb in to a heater hose (I saw one in the store 4 days ago)
1500 W = 37.22
2000W = 45.46 (better buy a heavy extension cord)
Old 12-03-2007, 10:51 AM   #10
Same for Toyota guys. I just ordered one last week for my Matrix from https://www.1sttoyotaparts.com/. It was $28 plus shipping which I'm guessing will be less than $10. As a side note its not listed on their site for some reason, so you'll have to call them.
Daox is offline   Reply With Quote
Broken Odometer PReta General Fuel Topics 6 12-15-2009 04:18 AM
1994 Geo Prism popimp General Fuel Topics 16 06-04-2007 02:18 PM
Gas Log? GasSavers_Kraig General Discussion (Off-Topic) 3 08-16-2006 01:21 AM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 02:44 PM
Smokey Yunick's hot vapor cycle engine GasSavers_maxc General Fuel Topics 0 06-09-2006 05:20 AM
