Block heater - Page 3 - Fuelly Forums
View Poll Results: How many of you have a block heater?
I do 14 27.45%
I dont 18 35.29%
I might get one 19 37.25%
Voters: 51. You may not vote on this poll
Old 08-11-2007, 06:09 PM   #21
Originally Posted by jandree22 View Post
Being a n00b I wasn't aware <snip>
Well judging by your avatar, you're only about 3 months old, so I'd say you shouldn't be to hard on yourself. :-) Cute photo...
Old 08-11-2007, 07:50 PM   #22
Originally Posted by Bill in Houston View Post
What's a block heater? ;-)
HAHA Bill I'm woundering WHY you don't know what is a block heater. If I was living in Houston, I would probably don't know either what the hell is that. You more likely to need a block colder .
Old 08-11-2007, 08:00 PM   #23
Originally Posted by cfg83 View Post
Hello -
Question. For those that have block heaters, can you name your brand/model, and where you got it? That would help for people who want to get one.
Thanks!
My EBH came as OEM . Northern tier Ford products come with them pre-installed or as dealer install option. It is a 'core plug' style .For newer vehicles there is the OE route ,for older vehicles try a Farm and Tractor supply (Fleet Farm , Farm & Fleet,CT Town and Country Stores etc ) NAPA ,CKS ,Advance,PepBoys O'Reily's should all be able to get them if not stocked.
Old 08-11-2007, 08:01 PM   #24
KARR's Avatar
Country: Portugal
I'm interesed to know if it's reliable to install one on my car, but I don't if they're available in my country. By the way, does this device self switches off when the propper engine temperature is reached?
KARR is offline   Reply With Quote
Old 08-11-2007, 08:06 PM   #25
Beings you have a diesel GM product , I'm betting that you can get one from a dealer . Try a UK supplier . There are many types some thermo controlled by a 'stat' & some that reach an op temp and hold it there . I have used a plug in outlet timer to switch it on/off every 2 hours - very handy when it hits -30&#176; and lower for two or three weeks straight!
Old 08-11-2007, 08:09 PM   #26
No, the block heater wont stop when the engine is hot. By the way, I noticed you lived in Portugal, I'm wondering, do you REALLY need a block heater. Because like I said in a post before, it's not very usefull UNLESS its minus 10 degree celcius during the night. And I really doubt that its will be the case. So don't look to install one, I dont suggest you to install one of these, its really for north country.
Old 08-11-2007, 08:09 PM   #27
omgwtfbyobbq's Avatar
Generally no. They are usually just a Cu AC heating element that stays on until turned off. The best bet would be to have a timer inline.
Old 08-11-2007, 08:10 PM   #28
Originally Posted by MnFocus View Post
Beings you have a diesel GM product , I'm betting that you can get one from a dealer . Try a UK supplier . There are many types some thermo controlled by a 'stat' & some that reach an op temp and hold it there . I have used a plug in outlet timer to switch it on/off every 2 hours - very handy when it hits -30? and lower for two or three weeks straight!
Or you can also use a timer to set it up 2 hours before you leave.
Old 08-11-2007, 08:15 PM   #29
Key thought is "realllllly cold" weather -otherwise Yes!-2 hours before hand .
I've found when it's that cold - a warm battery does much better at spinning the starter than a warm block . A BatteryTenderJr. gets the nod now.
Old 08-11-2007, 08:17 PM   #30
KARR's Avatar
Country: Portugal
OK! Definetely, the temperatures in Portugal never reach such extreme low values, except in some days during Winter. Thank you.
Fuel-up added screen? BDC Fuelly Web Support and Community News 3 06-10-2010 10:11 AM
More fun on FUELLY brytrkr1 Fuelly Web Support and Community News 3 12-06-2009 11:41 PM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 03:44 PM
New forum guidelines, FAQ Matt Timion Fuelly Web Support and Community News 14 05-21-2006 07:26 AM
